Phillips HD beam pattern
Old Jan 6, 2003 | 03:45 PM
TypeR1558's Avatar
New User
Default Phillips HD beam pattern
Installed the new Phillips HID kit, and the right side doesn't shine out quite as far as the left. I was told this is so oncoming traffic is not blinded on RHD cars.
My question: is there anyway to adjust the beam angle, so that both sides shine equally as bright/far?
EDIT: just got word from a friend that it's not possible to adjust the projectors. If anyone knows something we don't fill me in.
BTW, I have the JDM front.
[Modified by TypeR1558, 4:46 PM 1/6/2003]
Old Jan 6, 2003 | 04:16 PM
92TypeR's Avatar
FSAE
Default Re: Phillips HD beam pattern (TypeR1558)
I remember from a thread a while ago that the right side beam is always higher because or the RHD roads. Basically, they were made to do the opposite of what you want
Old Jan 6, 2003 | 09:30 PM
TypeR1558's Avatar
New User
Default Re: Phillips HD beam pattern (92TypeR)
Nope, the left hand side shines farther. So, not as bad as you thought, but would be nice to even it out...
Old Jan 6, 2003 | 09:59 PM
92TypeR's Avatar
FSAE
DOH! that is what i meant
Old Jan 7, 2003 | 04:41 AM
Ricky Rojales's Avatar
It is not possible. The light spread/pattern is the reverse of USDM vehicles. You'll just have to accept what you have or go back to stock.
Old Jan 7, 2003 | 04:47 AM
Mario's Avatar
Default Re: Phillips HD beam pattern (Clonaid)
Actualy, that isn't 100% correct.
If you want, you can disassemble the projector housing and swap the inner projector shields in the opposite direction. In effect, re-reversing the beam pattern.
Old Jan 7, 2003 | 07:07 AM
Default Re: Phillips HD beam pattern (Mario)
Well, yeah, you could do that. But, you'd still have a beam pattern that was slightly biased towards the left as opposed to the right, like on USDM vehicles. It's a compromise. Or, you could go all out just get some USDM Audi/BMW(Bosch) projectors and accomplish something similar to the USDM Audi/BMW light pattern. You'd also get the purple/white color change in the later case.
Old Jan 7, 2003 | 08:54 AM
98R-1144's Avatar
I'm in the same boat. However, I just lowered the left side down a little... and the ride side I aimed as faaaaaaaaaaaar right as possible. Works pretty good!
4_door_eg
18
Apr 3, 2007 01:24 PM
Petah
Mar 8, 2004 01:08 AM
Sticky Tires
Dec 23, 2002 10:42 AM
EJK
Oct 9, 2001 07:37 PM
