Toda spring/reatiner Install. . . HELP ! ! !
its time to assemble the head...
Toda springs/retainers
Spec b's
Cam Gears
cams and gears are easy, iv dont those before. But iv never installed springs.
is it a basic install just follow hlms and use all factory specs or are there different clearences?
what about this ( **1.325 ) installed Height ?
can anyone explain this to me.
is there anything else i should know before doing this? ? ? or is it cut and dry get the tools and follow the manual ?
looking to do this tomarrow , so any quick feedback would help !
Spec b's
Cam Gears
i don't have the answer just wanted to know where you got your stuff from. i'm looking into doing the same thing to my car once i get my income tax check.
somebody help him because you're helping me too!!!
Normal installation is what you are supposed to do.
See my signature.
It is a pretty straigth foward installation.
When working on a particular piston, raise it to TDC so there is no chance of the valve sliding in to far in the combustion chamber. Also take extra care not to lose those half cone locking the valve, springs and retainer in place (I had to order a few of those from Acura after I lost one).
If I am not mistaken the install height is the minimum height the spring should be after installation so it does not "bottom out" when compressed by the camshaft lobe (creating excessive wear on the retainers, rockers, lobes...). If the install height is lower then spec, you would need to machine the spring sitting surface to lower it a little.
Also use the specs from Toda when adjusting lobe to rocker clearance (valve adjustment) 0.2mm for all valves if I remember correctly.
[Modified by JPP, 1:12 PM 1/5/2003]
[Modified by JPP, 1:16 PM 1/5/2003]
your saying it shouldnt be shorter ( or is it taller) than **1.325 installed Height.
also im doing this with head off the car... so i cant keep it at TDC, any other suggestions that would help me out.
i dont want to start untill i deffinatly know what i am doing.
head off the car, dont worry about the tdc thing.
as far as install height, you probably dont have to worry about it with those
small cams. toda springs give you A LOT of leeway.
When doing valve springs, try a little Honda power steering grease (vasoline) on the valve keepers/retainers. It is amazing how few keepers you will lose.
If your looking for a great shop to buy/install Toda parts, I would suggest Vroom Vroom Motorsports in sacramento. The owner Edison is very knowledgable and deals with TODA on a consistant basis.
[Modified by PYMUGENITR, 5:51 PM 1/6/2003]
MadtownSi
Sep 19, 2002 12:33 PM
