HELP! Parking brake keeps turning on by itself!
Old Feb 2, 2025 | 06:44 AM
Kaysuii's Avatar
Default HELP! Parking brake keeps turning on by itself!
Hi all. First time poster here. I’ve come into a problem that has me and my car guy stumped. We’ve recently replaced a broken abs speed sensor (back passenger), not sure if that’s playing a role in this issue or not so I’m adding it in.
Two issues:
1. If I use my parking brake, sometimes I can’t get it to go back off.
2. Sometimes the parking break randomly turns on by itself without me touching it when I park and then it won’t turn back off. I’ve had it turn off after turning my car back on once or twice before but this time it’s not turning off.
What could be the cause of this and is it an easy fix? Speak to me like I’m dumb, I’m not a car girl. lol 😅
Thanks for all your help.
Old Feb 2, 2025 | 07:41 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: HELP! Parking brake keeps turning on by itself!
What year and model vehicle is this?
Old Feb 2, 2025 | 10:54 AM
Kaysuii's Avatar
2018 HRV
Old Feb 2, 2025 | 11:45 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The wheel speed sensor is part of the Electric Parking Brake circuit. It may or may not have anything to do with what is occurring
Why was the wheel speed sensor replaced? Was there something else repaired/replaced before this, such as brake pads, etc?
Recommend getting the car scanned with a scanner capable of reading Honda ABS/VSA trouble codes to try to narrow down the cause.
Old Feb 2, 2025 | 01:27 PM
Kaysuii's Avatar
We replaced the wheel bearing before that and in the process broke the speed sensor.
I’m guessing Honda dealerships will be the only place that has such a scanner, right? My car guy has a fancy scanner because he works on lots of vehicles for work and for fun, is it possible for him to have one of those scanners?
Thanks for your replies. It’s really appreciated.
Old Feb 2, 2025 | 01:47 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
There are many scanners that can read Honda ABS/VSA codes. It is the basic ones that don't.
Have your car guy try to scan for codes.
Old Feb 2, 2025 | 02:10 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
To replace the wheel bearing, the brake caliper and pads needs to removed. Due to the electric parking brake, the brake system needs to be put into the "maintenance mode" before that. If this was not done properly, either electronically or manually, there is a possibility this caused a malfunction in the electric parking brake actuator. When there is a malfunction in the electric parking brake system, the parking brake may not release.
Old Feb 2, 2025 | 03:06 PM
Kaysuii's Avatar
I don’t think it was put into maintenance mode when we did the bearing. We worked on it just before we met my car guy. He ended up helping us finish the job because we were having a hard time. Maybe he put it in maintenance mode? I’m not sure.
How can this malfunction be fixed? Do I have to replace the actuator?
Old Feb 2, 2025 | 04:01 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Get the car scanned for trouble codes first to see if it may help narrow down the potential culprit.
charlieboy88
Jan 4, 2013 07:58 AM
dannetech
Nov 20, 2011 03:59 PM
super china china
Jul 8, 2007 12:18 PM
DeL SLo
Sep 2, 2002 01:57 AM
