tps calibration on s300
Old Oct 10, 2018 | 04:28 AM
spoolinvtec54's Avatar
Default tps calibration on s300
On my all motor b series I put skunk2 race manifold and 90mm throttle body. I calibrated my tps .50v closed throttle and 4.5v wot. when I go into smanger to set it up there. I get -5% closed and 60% open and idea how to fix that. Thanks
Old Oct 10, 2018 | 05:14 AM
1999 Civic Si's Avatar
Default Re: tps calibration on s300
It has been a bit since I have done it, but have you read the throttle position with it closed and with it open?
There is a button next to the percentages that you click "read", this is when you have your laptop hooked up to the ecu and your tune file open, click the button when the throttle is closed and then hit it again at WOT. You can also go under the S300 ECU Guide and go to TPS Parameters and read more about it.
Old Oct 10, 2018 | 05:55 AM
the -5% and 60% is when I click on the read button with it hooked up to the laptop.
Old Oct 11, 2018 | 03:42 AM
so I put the old throttle body and another tps on I'm still getting the same numbers. I was going threw smanger and the map sensor is not reading. so its either the ecu or the wiring harness. has anyone ever had s300 not reading sensors
Old Oct 11, 2018 | 08:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Your MAP and TPS sensor plugs are swapped... switch them and try again.
Old Oct 12, 2018 | 04:42 AM
I tried swapping them. it does nothing
Old Oct 12, 2018 | 04:47 AM
on s300 display I'm getting with the car off. the number never change. its either the hondata s300 which is new or new wireworx harness.
map -29
ect 302
iat 302
tps -13
Old Oct 12, 2018 | 08:19 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Sounds dumb but make sure you have the most current Version of smanager. If you do already you can test the voltage at the ecu plug for tps voltage and make sure your getting good continuity from the engine harness to the ecu.
Old Oct 13, 2018 | 06:35 PM
flesh199's Avatar
Try another s300 from a friends car first for testing.Ive got a friend with those same prob and the s300 was not installed right in the board
Old Oct 13, 2018 | 08:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Is the J12 jumper cut in your ECU ???
Old Oct 16, 2018 | 03:02 PM
I would try another ecu but no one around me has S300. I will check the jumper.
Old Oct 30, 2018 | 07:11 PM
So sent the ecu out and the harness to get looked at . They said everything was good . Got it back put it all back together and everything worked for couple days then. Tonight I plugged my laptop in and I’m getting samething the ecu is flashing red . Need help thanks
Old Oct 30, 2018 | 07:12 PM
Yes J 12 is cut out
Old Nov 1, 2018 | 08:38 AM
Loved
Community Favorite
Have you verified tps voltage at ecu pin d11 yet?
Old Nov 1, 2018 | 01:58 PM
No
Old Nov 1, 2018 | 02:00 PM
I’m not think it’s a tps issue
Old Nov 1, 2018 | 02:01 PM
This what I’m getting no matter what I do. it never changes with the car on or off.
Old Nov 2, 2018 | 03:38 PM
Loved
Community Favorite
Have you updated the USB drivers to make sure they are working. Doesn't seem like the ecu and laptop are getting a good communication.
Old Nov 3, 2018 | 09:44 AM
How do u update the usb driver
Old Nov 3, 2018 | 09:47 AM
If I do the usb update . That probably won’t fix the ecu from flashing red with usb not even plugged it in right.
Old Jun 5, 2020 | 11:03 AM
hazza3198's Avatar
Did this ever get resolved? Having the same issue with mine -5% & 60% etc etc and it doesn’t read any movement from the TPS.
thanks
Old Jun 8, 2020 | 03:26 AM
The ecu was junk. I Got another one worked perfectly.
1996ek9
Dec 10, 2016 03:54 PM
elnene_2012
May 30, 2016 08:33 AM
94boostedhatch
Oct 27, 2015 01:25 AM
95turbodteg
Honda Civic (2006 - 2015)
14
May 6, 2010 07:14 PM
Sideshow9090
Dec 2, 2005 06:10 AM
