Chassis question. Eg subframe/Ek chassis knuckles
Old Jun 22, 2017 | 09:47 PM
Ron Burgandy's Avatar
Default Chassis question. Eg subframe/Ek chassis knuckles
The problem:
I've had a weird suspension issue- at this point, with my camber correction all the backed out, I cannot get less than -3deg camber.
The facts:
98 ek hatch chassis, swapped to EG subframe to accommodate spherical bushings. Unsure of knuckles.
Questions-
Are their compatibility issues with ek, eg subframes and the geometry of certain knuckles?
Would having Integra knuckles on an eg subframe and an ek chassis cause issues?
what is the ideal setup for my situation?
thanks in advance.
Old Jun 23, 2017 | 06:05 AM
AZ_CIVIC's Avatar
Default Re: Chassis question. Eg subframe/Ek chassis knuckles
Originally Posted by Ron Burgandy
The problem:
The facts:
Questions-
thanks in advance.
That's pretty weird. I have not had any issues like that and I did the same setup as you.
Old Jun 23, 2017 | 11:37 PM
but what knuckles are on your car? EK or Integra?
Old Jun 24, 2017 | 06:14 AM
AZ_CIVIC's Avatar
EK
Old Jun 24, 2017 | 04:24 PM
EK
see I think my knuckles are DC. I think the DC knuckles are .5" different. That might explain it.
Old Jul 7, 2019 | 10:10 PM
Problem solved-
Just in case anyone searches this with the same issue.
The issue sue was simple- I had Integra DA knuckles. They have more curve to the upper arm that attaches to the camber correction mount and therefore my -3-4deg camber.
So getting a knuckle assembly from an ek or EG/DC solved my problem. (Note, if you are running DSS hubs you must be sure to get the knuckles with ABS or 99-00 SI. Otherwise you will have wheel bearing compatibility issues)
cheers.
fishy21
Suspension & Brakes
May 12, 2010 09:36 PM
Thatoneguy206
Apr 13, 2010 06:32 PM
PJ_Sir
Mar 20, 2008 02:49 PM
J. Tippy
Suspension & Brakes
May 18, 2007 11:08 AM
