Is there such a thing as a "quiet" wastegate?
Old Mar 7, 2006 | 08:37 AM
H20too's Avatar
Default Is there such a thing as a "quiet" wastegate?
Does anyone know of a wastegate that is quieter then the tial 38mm? I would rather here my turbo spooling than hear all the loud exhaust coming from my dump pipe... No internal either, gotta be external...
thanks!!!
Old Mar 7, 2006 | 08:42 AM
MoonScryer's Avatar
Consider plumbing the dumptube into the exhaust system downstream of the o2 sensor? That should help.
Old Mar 7, 2006 | 08:44 AM
Schister66's Avatar
Man U FTW
its not the wastegate that's making the noise, its your exhaust leaving it....i'm sure there's a better and quieter way to release the exhaust, but i really think you should take the above advice......that would be the best solution i think!!
Old Mar 7, 2006 | 09:00 AM
ImportMotorSpec's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MoonScryer &raquo;</TD></TR><TR><TD CLASS="quote">Consider plumbing the dumptube into the exhaust system downstream of the o2 sensor? That should help.</TD></TR></TABLE>
Exactly what you should do. You will mever hear it then.
Old Mar 7, 2006 | 03:18 PM
yee SERIOUS's Avatar
Default Re: (MoonScryer)
yeah i don't like the sound of mine either. i might have to tube it into the dp. but does it have to be after the o2 sensor? i'm wondering if it could effect tune if it's before the o2?
Old Mar 7, 2006 | 03:26 PM
Bailhatch's Avatar
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah i don't like the sound of mine either. i might have to tube it into the dp. but does it have to be after the o2 sensor? i'm wondering if it could effect tune if it's before the o2?</TD></TR></TABLE>
it doesnt matter if its after or before the o2 at all. Its the same exact exhasut that goes out your exhaust.
Old Mar 7, 2006 | 03:28 PM
H20too's Avatar
Default Re: (Bailhatch)
will this take away any power? i read somewhere that if you plumb it back in you lose around 30 hp??? I seriously doubt it's that much, if any. For those of you that do have it plumbed back in, is it quiet enough to hear the turbo all the way up to full boost?
Old Mar 7, 2006 | 04:43 PM
Mugencrxsir1's Avatar
Default Re: Is there such a thing as a "quiet" wastegate? (H20too)
I've seen some domestic guys put a little lawn mower mufflers on the ends of wastegate dump tube to quiet the outgoing exhaust. If i was'nt going to recycle the gas, I was acutally thinking of doing it that way. I know you guys will like that one.
Old Mar 7, 2006 | 06:31 PM
all go teg's Avatar
Default Re: Is there such a thing as a "quiet" wastegate? (Mugencrxsir1)
if you were going to have a closed loop dumptube, how far away from the turbo would someone recommend placing tube into the down pipe? also to any one that has done it, do you have pics you wouldn't mind posting up?
Old Mar 7, 2006 | 06:42 PM
Soccerking3000's Avatar
Default Re: Is there such a thing as a "quiet" wastegate? (all go teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all go teg &raquo;</TD></TR><TR><TD CLASS="quote">if you were going to have a closed loop dumptube, how far away from the turbo would someone recommend placing tube into the down pipe? also to any one that has done it, do you have pics you wouldn't mind posting up?</TD></TR></TABLE>
fullrace did some test and found that its best to dump underneath the oilpan so i would assume that is also the best place to merge it into the downpipe/exhaust
Old Mar 7, 2006 | 06:46 PM
adictionbass's Avatar
here you go man... lol, hows that teg holding up?
Its mild steel and migged, get over it. first one ive done:
Old Mar 7, 2006 | 07:38 PM
all go teg's Avatar
Default Re: Is there such a thing as a "quiet" wastegate? (adictionbass)
hey man, its holdin up great, now i just want more lol, but i wish we had done that for mine.
Old Mar 8, 2006 | 08:37 AM
H20too's Avatar
is the flex pipe really necassary? Good job by the way!!! I guess now would be a great time to upgrade to a 3" downpipe...
Old Mar 8, 2006 | 09:44 AM
emotionisdead's Avatar
Very Emergency!!
i have considered doing this on my turbo setup. defintley makes the car more quite in boost. now if onnly you could run a stock airbox with the BOV plumbed into it.
Old Mar 8, 2006 | 10:14 AM
i think imma get a mini muffler lol
Old Mar 8, 2006 | 10:20 AM
tek_civic's Avatar
if you don't want a BOV sound, buy a recirculation valve(diverter valve) the audi/vw guys(as well as others) use em, they function the same, reliable, decent looking.
all you would have to do is attach it to your charge piping, and route a tube into your intake somewhere(non charged side of course). hell you can do it with some BOVs like the greddy type s for one.
Old Mar 8, 2006 | 01:09 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (tek_civic)
wastegate... not bov
Old Mar 8, 2006 | 01:15 PM
BoostedEG6's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emotionisdead &raquo;</TD></TR><TR><TD CLASS="quote"> now if onnly you could run a stock airbox with the BOV plumbed into it. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">if you don't want a BOV sound, buy a recirculation valve(diverter valve) the audi/vw guys(as well as others) use em, they function the same, reliable, decent looking.
all you would have to do is attach it to your charge piping, and route a tube into your intake somewhere(non charged side of course). hell you can do it with some BOVs like the greddy type s for one.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">wastegate... not bov </TD></TR></TABLE>
Old Mar 8, 2006 | 01:24 PM
-RedneckDave-'s Avatar
Working
Default Re: (BoostedEG6)
Just slash cut the dump tube and it should make it quieter.
Old Mar 8, 2006 | 02:27 PM
meseetree's Avatar
yeah.
the HKS fitment is $5 from ebay, the Turbo XS one you can screw an end on it the is threaded on one and smooth on the other to run the pipe..
Old Mar 8, 2006 | 05:59 PM
alex_s817's Avatar
Default Re: (meseetree)
ill have to find the magazine but a couple years back, someone just ran the dumptube to the right of the motor and welded a yoshimura motorcycle exhaust to the end of it. the chrome tip came out of the fender right in front of the left front wheel. it looked pretty cool, except you have to cut your bumper. was supposedly really quiet too
Old Mar 8, 2006 | 06:55 PM
H20too's Avatar
Default Re: (alex_s817)
seems like it would be easier just to dump it back into the downpipe...
fcluddington
Engine Management and Tuning
Apr 7, 2011 04:54 AM
4dek
Mar 8, 2008 10:39 PM
tobe1424
Aug 12, 2007 11:23 AM
tweekerz
Jan 25, 2007 08:15 AM
T--Rex
May 20, 2005 03:29 PM
