ctr or itr pistons?
Old Jan 2, 2005 | 05:19 PM
greasemonkeys's Avatar
Default ctr or itr pistons?
which pistons would be most effective for an all motor b16a1, ctr or itr, and also what mods if any need to be done to fit them on stock rods?
Old Jan 2, 2005 | 06:15 PM
PodRacerSi's Avatar
Default Re: ctr or itr pistons? (prodigysir)
Ctr's will give you a little bit higher compression. You will need to have the rods milled down about 1 mm for them to fit into the ctr pistons though. Other than that they fit right in.
Old Jan 2, 2005 | 08:28 PM
Default Re: ctr or itr pistons? (PodRacerSi)
do itr pistons fit arent they the same bore
Old Jan 2, 2005 | 08:37 PM
SiKid86's Avatar
like the other guy said... They'll fit too but will yeild less CR than the CTR...
Old Jan 7, 2005 | 01:24 PM
Jun8386's Avatar
Default Re: ctr or itr pistons? (SiKid86)
if your not wanting to build a race car run P30 or itr pistons.
Old Jan 7, 2005 | 03:16 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prodigysir &raquo;</TD></TR><TR><TD CLASS="quote">do itr pistons fit arent they the same bore</TD></TR></TABLE>
ITR pistons will provide a lower C/R than the stock setup, so you probably don't want to go that route.
Old Jan 7, 2005 | 06:41 PM
00000xxx's Avatar
Default Re: ctr or itr pistons? (Padawan)
JDM ITR pistons: 10.1:1 CR
USDM ITR pistons: 9.7:1 CR
CTR pistons: 10.8:1 CR
def go with CTR pistons, you could also find some CTR connecting rods if your worried about milling them to fit,
http://www.c-speedracing.com/h...c.php
http://store.yahoo.com/yhst-14....html
get the oversize .25, bore and hone the cylinder walls
GSR_hatch936
11
Jan 10, 2008 12:06 PM
CaseBone
32
Apr 3, 2007 05:15 AM
ELSUICIDA
Nov 23, 2006 08:55 AM
mugen12_35sec
Apr 13, 2006 04:20 AM
eddiecut
Feb 11, 2003 10:12 AM
