Honda Fit Honda Fit (Jazz)
2011 fit throttle control relay location
Old 05-25-2019, 07:45 AM
carlos8's Avatar
Default 2011 fit throttle control relay location
Where's the throttle control relay located in this fit?
thanks
Old 05-25-2019, 08:49 AM
Global Moderator
tech8's Avatar
Default Re: 2011 fit throttle control relay location
For North American Honda Fits, the ETCS Control Relay is located in the under-dash fuse/relay box.
Old 05-25-2019, 09:55 AM
carlos8's Avatar
It's the number 32, Throttle actuator control module relay in the fuse box diagram?
Old 05-25-2019, 08:01 PM
Global Moderator
tech8's Avatar
Generally, relays are not labeled as part of the owner's manual.
On the top of the fuse/relay box is a row of relays. From left to right, the ETCS Control Relay should be the 7th relay.
savemyjazz
Honda Fit
07-23-2018 06:52 PM
jm3d
03-02-2018 03:19 PM
Muydos
06-03-2012 03:32 PM
Juniorhatch
Acura TL, RL & ZDX
04-21-2010 06:58 PM
hondarondon9296
12-24-2009 06:55 AM
Quick Reply: 2011 fit throttle control relay location
