What oil is optimal to use for a bone stock JDM B18C1?
Was wondering what oil is best to use for my jdm b18c? My tune said to go with mobile1 10w30 but idk if it's ok because the engine is a 5w30 normally I do drive really hard daily idk if that makes a difference any help will grandly be appreciated thanx in advance
re: What oil is optimal to use for a bone stock JDM B18C1?
If you stick with high quality synthetic oils, anything a 10W-30 can do, a 5W-30 can do better. Then again, anything a 10W-30 or 5W-30 can do, a 0W-30 can do even better.
Re: What oil is optimal to use for a bone stock JDM B18C1?
Climate is also a big factor that affects oil temp.
Listen to your tuner, he's right, especially if you live in a warm climate area. If you drive hard, and live in a warm climate, use 10w-30. If you live in a cold climate, you'll be better with 5w-30.
If you use too thin of oil (0w-30), you WILL damage all moving parts. The same applies to using too thick of an oil.
And no, 10w-30, 5w-30, and 0w-30 DO NOT have the same viscosity at operating temp.
As for what brand and type of oil to use, you want something with high ZDDP due to the type of valvetrain hondas use. So again, your tuner was right to recommend Mobil1. BUT, regular Mobil1 actually doesn't have that high of ZDDP. It's higher than most other oils, but not by much. The exact oil you want is Mobil1 Extended Performance. It has a much much higher ZDDP content. Another equally good alternative is Valvoline VR-1 oil
False. Optimal oil viscosity depends on oil temps and bearing clearances. Some engines require thinner oil due to tighter clearances and cooler oil temps. Other engines require thicker oil due to looser clearances and hotter oil temps.
Moderator
Oil dilution has nothing to do with whether the oil is 10W-, 5W-, or 0W-, it is a function of the engine itself. Said another way, even if you ran a straight weight 30 oil, oil dilution would be just as bad as if it was if you were running a 0W-30.
-to say 0w-30 is far superior to anything else is a very biased, and incorrect, personal opinion. Especially when zero facts have been brought to the table to back up your personal opinion.
-again, it all boils down to viscosity. And ideal viscosity depends on operating temp of the oil, and bearing clearances.
-you need to do some research on how viscosity ratings are determined. you obviously don't know what you're spewing. While you're at it, check out the actual viscosities of various viscosity ratings at various temps from same manufacturer and different manufacturers.
The fact is, 10W-30 uses what is effectively "rot gut" base oil compared to 5W and 0W; to take it one step further, 0W-xx oils use base oils of such high grade they require very few viscosity improvers to prevent from thinning below grade specification. Like it or don't, believe it or not, your holy grail 10W-30 is of the lowest grade xW-30 oils on the market.
-ALL oils are part synthetic now, by federal law, except those labelled as full synthetic.
-comparing 10w-30 conventional walmart brand oil to a the top tier 0w-30 oil is not even a comparison. Obviously the 0w-30 in this scenario would be a better QUALITY oil, but it would still be the WRONG VISCOSITY.
-comparing 10w-30 to 0w-30 of the exact same brand and type of oil, like say Valvoline VR1 oil, the oil quality will be absolutely identical. Because they're the same oil, manufactured exactly the same, with the same bases that are all synthetic and lab created, no crude oil (or "rot gut" oil as your have claimed), and everything about them will be nearly exactly the same EXCEPT VISCOSITY
-you used the word "patently" quite incorrectly
-The fact is you're wrong. '"Rot gut" base oil' is also a biased personal opinion, and again is wrong.
-ALL oils are part synthetic now, by federal law, except those labelled as full synthetic. That means ALL conventional oils are made with the SAME base oils.
-comparing 10w-30 to 0w-30 of the exact same brand and type of oil, like say Valvoline VR1 oil, the oil quality will be absolutely identical. Because they're the same damn oil, manufactured exactly the same, with the same bases that are all synthetic and lab created, no crude oil (or "rot gut" oil as your have claimed), and everything about them will be exactly the same EXCEPT VISCOSITY
