Fresh machined gar crank hard to spin crank when installed
Hi everybody I知 new to the formuns and need some advice. Today I went to go Gap my pistons rings for my gsr block I知 rebuilding. Now the block is on a engine stand with only the crank installed I spun the crank over a couple times and it move fairly easy by hand but I heard a faint scraping noise immediately remove the crank to find it was hitting a oil squirter. Solved that issue and reinstalled the crank. After torquing down all the main cap to spec and checking to see if the crank clears them all I notice that it seemed a bit harder to spin (only crank installed no pistons or rods) on initial rotation once it痴 spinning is not so hard to move. Does anyone have any feedback or has anyone experience anything like this?
Re: Fresh machined gar crank hard to spin crank when installed
Did you install the crank caps in the correct location and in the correct orientation? They are labelled for position and orientation
Are you sure that the crank girdle/caps came from this original motor?I saw that in the past someone installed another crank caps/girdle from another block.Get some plastigauge for check you clearance first!
I just got done plastigauging the crank everything measured within .0015 of an in clean all the journals and added assembly lube and torqued down and she痴 spinning as freely as ever. Thank you all
O.G. triple O.G.
My block has a different crankshaft and it's fine. Just as long as the clearance is within spec and bearings are the correct size, it will work fine.
there's a difference between crankshaft and crank caps. you can swap cranks to no end. You can not swap crank caps without major machine work
