Good cheap exhaust
Good cheap exhaust
Ok this is my first post so sorry if its in the wrong place or whatever, i tried using the search bar but its restrictions wouldnt work with me on my searches. The situation is i bought a 97 civic hatch a couple months ago and the exhaust was cut off at the cat by the previous owner, since its just my beater i was just gonna run it till it died but now my header is cracked and i dont wany to burn out my exhaust valves and kill the car sooner, new stock exhaust would be over $300 so i dont want to go that route so im looking for a decent exhaust thats cheap and not too loud.
Stancetard Hate Monger
Re: Good cheap exhaust
does this hatch have cat on manifold? if it does, and you have emissions your options are as follows: 1: buy a used oem b7/z6/y8 manifold, or an aftermarket manifold for the same engines, an oe equivalent cat for a 96-00 civic ex, extend secondary o2 wiring, install new exhaust. 2: buy a replacement oe style cat on manifold, replace exhaust. i would personally go with 1, given as the cat on manifold setup is more expensive. you'll recoup 50-65$ on scrapping the factory converter as well. as to a decent but not expensive exhaust, i'd recommend yonaka.
Sorry for my delayed response everyone, i ended up driving the car to preheat the header and dual pass welded the crack with a 6011 stick welder and it seems to be holding up very well so far. Put about 2k miles on it since i posted this.
Try Walker: https://www.rockauto.com/en/moreinfo...168882&jsn=367
The above is for a 96 Civic DX and displays a "top cat" configuration. I replaced the original cat
20 months ago w/ a Dorman. Replaced the mid-pipe, a Walker, almost 9 yrs ago.
The muffler, also a Walker, has been replaced twice in the last 9 yrs. If the rubber hangers are Honda,
hold onto them. They last forever. Unlike Walkers, which start to degrade wi/ a yr or two.
Mason Dixon
15
06-18-2013 06:16 PM
94 IntegraLS
06-21-2011 06:17 AM
GiMpInThaCiv
03-21-2006 08:46 PM
