1994 Civic Hatch Fuel Problem
So, after having somebody cut the ends off my fuel pump, i have now gone and replaced the fuel pump assembly and pump. When i turn the key the pump kicks in, and i can feel it filling the line with pressure but nothing reaches the engine side.
I pulled the fuel filter & hose from it and there was 0 pressure. the line that runs from the fuel pump to underneath the fuel filter i can force air from engine side --> Fuel pump side. But when I try to force air from Pump side --> engine side, its blocked.. Nothing comes through.
So my problem isnt that the line is clogged because i can blow backwards into it and it shoots gas all over the rear hatch. This problems isn't letting fuel reach the front, the pump just primes and eventually sounds like **** because theirs too much pressure.. any ideas?
Front of car Fuel Pump Hose
Air will flow this way
But not this way
But not this way
Re: 1994 Civic Hatch Fuel Problem
Replace the obstructed fuel line.
New fuel pump, I even used the one from my other car ( walbro 255LPH ). If its obstructed how come air freely flows one direction and not the other?
Undergroundeg6
07-19-2013 01:23 PM
cleo7
01-23-2013 08:53 AM
