d16y7 gas found in intake manifold
Old 12-07-2018, 04:52 PM
mx5med's Avatar
Default d16y7 gas found in intake manifold
While chasing a few other issues (poor gas mileage and high fuel trim) I found small puddle of gas sitting in the bottom of my intake manifold. Could this be an injector issue or something else? Everything is stock on the car, Y7 automatic. 208,000 miles
Old 12-07-2018, 05:17 PM
-Intl Steve Krew
Caoboy's Avatar
Default Re: d16y7 gas found in intake manifold
Sounds like you have an injector leaking, and based on your spark plug pic I’d go with the cylinder that had the dark plug
Old 12-07-2018, 05:36 PM
mx5med's Avatar
Is it worth trying to clean the injector out? Maybe changing cylinders then to see if it keeps doing the same thing?
Old 12-07-2018, 05:37 PM
-Intl Steve Krew
Caoboy's Avatar
At minimum you could spend the money to have all the injectors cleaned, or just replace them.
Old 12-08-2018, 05:44 PM
mx5med's Avatar
Can anyone confirm if its across the board that all 99 y7's came from factory with green tipped injectors? Mine has brown tipped which I believe are higher flow. I'm planning to switch back to the green tips after cleaning a set up I got from the junkyard.
Old 12-08-2018, 07:27 PM
Stancetard Hate Monger
eghatch9295's Avatar
190cc. do not know color
Old 12-09-2018, 01:15 PM
mx5med's Avatar
So I'm just wanting to confirm once more with more info before I take the time to install these
I believe these were out of a 98, I know for sure it was a d16y7 though. Keihin injectors with 6KK5 printed on one side of the injector. I couldn't find any info on them other than those numbers and that they have a green tip. I'm not home to see what the current injectors in my car are, but I'll post when I see those.
Old 12-09-2018, 06:04 PM
as long as it was a y7, you're good.
Old 12-11-2018, 08:02 AM
mx5med's Avatar
Injectors went in nice. Here is a picture of my #4 plug after about 200 miles. The black looks wet in the picture, but is completely dry like soot. I have no idea how to read plugs, so what would be causing this?
Old 12-14-2018, 06:44 AM
mx5med's Avatar
Anyone able to help in reading the spark plug for me?
Old 12-14-2018, 07:41 AM
https://www.aa1car.com/library/spark_plug_fouling.htm
https://i.pinimg.com/originals/30/3e...fb21169bfa.jpg
BlueByYou
03-14-2013 07:19 PM
Despiteful
12-26-2011 07:36 PM
dohdoh420
11
09-08-2006 10:12 AM
NYCsnowman
01-11-2006 09:26 AM
91_HB
03-28-2005 03:01 PM
Quick Reply: d16y7 gas found in intake manifold
