5th gear cuff bearing size question
Old 09-24-2018, 12:28 PM
eh2_Trav's Avatar
Default 5th gear cuff bearing size question
I was hoping that someone could tell me the bearing size that goes on the mainshaft side of the 5th gear cuff. I purchased the cuff about a year ago, never really opened the boxes at the bearings came in, as I was stock piling parts for my build. But once I started to install it on the transmission I soon realized that I got sent two of the same bearing , by accident im sure. As you can see in the pictures, when that bearing is on the main shaft side there is about a quarter inch gap. Was just curious if anybody had the bearing size that goes on the main shaft side so I can put the trans back together. I currently in contact with Synchrotech but I’m sure I won’t be able to find my invoice since my purchase was quite some time ago. Thanks for any help.
Old 09-24-2018, 09:28 PM
JRCivic1's Avatar
Default Re: 5th gear cuff bearing size question
I suggest you give them a call and tell them your story. At worst, you may have to buy a replacement bearing. At least they will know EXACTLY what you need. Good luck.
VTEC-ALL-DAY!
12-17-2013 04:43 PM
SPOOLINmatt
01-07-2008 05:32 AM
Sack Master
07-01-2004 09:16 AM
TREVER
01-12-2003 02:57 AM
Quick Reply: 5th gear cuff bearing size question
