What ecu is obd2 for a 00’ b20 Engine
Re: What ecu is obd2 for a 00’ b20 Engine
What vehicle are you going to install the engine in ??? Do you have to get your car inspected/BARRED each year ???
You would need a '00 CRV manual ECU. The part number is 37820-PHK-A03. I can't remember if the CRV has an immobilizer or not... if it does, you will have to find a work around.
I’ve got one of those in storage in my garage. Message me if you’re interested.
EDIT: There wasn’t an immobilizer in mine.
The 00 crv does not have an immobilizer in it. I pulled one out of the junkyard and put it in my B20 swapped EK. Ran perfect until I went B20/vtec. Make me an offer on it just need it gone.
I already bought one :/ Thanks though! My distributor has a crack around where the spark plug would go into, Would any 96-00 B series distributor work ?
I think the B16 blocks were shorter than the B18 and B20, so a b16 header may have some fitment issues around the oil pan. I think all the B-series header flanges are the same where they bolt to the heads.
Any NON-Vtec "B" series distributor from a '96-01 Integra or '97-01 CRV would "WORK"... but the plug styles are different, so you may have to create an adapter harness between your engine harness and the distributor plug.
would one off a B20B4 work ? Dont know the differences between the B20b and b20b4
TwoFacedCustoms
08-13-2010 11:52 AM
