Does head gasket sealer wreck water pump seals?
Old 07-11-2018, 08:15 PM
LSteggyguy's Avatar
Default Does head gasket sealer wreck water pump seals?
I had a D16y8 with a water pump that only had 30k miles on it. The head gasket let go and I didn't want to do the replacement job so I poured in a bottle of blue devil head gasket sealer.
Within a few minutes of idling it started puking coolant out of the weep hole of the water pump. I ended up doing the head gasket job and replacing the water pump because everything was so messed up at that point and it's been holding strong since then
I also had another civic with a bad head gasket that had a leaking water pump from the weep hole, water pump looked to be in pretty good shape, no corrosion on the impeller and it looked pretty new. I thought that was odd so I went ahead and did a timing belt and water pump job on it and poured the used coolant back into it.
Lo and behold my brand new water pump starts puking coolant from both weep holes after a few minutes of idling.
What the hell? I can only guess that they used blue devil head gasket sealer because the overflow bottle was full of a blue liquid and like a dumbass I just poured it into my bucket and then poured the bucket back into the rad. Is it destroying the water pump seal? Or is it just thinning the coolant out to the point where it can leak past the seal???
Old 07-12-2018, 02:22 AM
O.G. triple O.G.
NVturbo's Avatar
Default Re: Does head gasket sealer wreck water pump seals?
those liquid sealer stuff should be outlawed. All they do is gunk up and clogged parts such as water pumps.
Old 07-12-2018, 04:27 AM
Fish Twig
tony_2018's Avatar
If you want to find out, why not inspect your water pump
Old 07-12-2018, 06:31 AM
LSteggyguy's Avatar
And what exactly am I looking for? I can't see the impeller seal because it's behind the impeller of course. And even then, It's it's probably too small of a leak to see any damage to the seal with the naked eye anyways.
Old 07-12-2018, 11:17 PM
Stancetard Hate Monger
eghatch9295's Avatar
lesson(s) learned. trying to save $10 vs hours of your time and new parts= not smart. DO NOT EVER use any kind of mechanic in a can horsecockery in your car. EVER. for any reason.
Old 07-13-2018, 09:36 AM
LSteggyguy's Avatar
Well yeah, I'm not going to use head gasket sealer again in a honda. I've actually used it in a nissan before and it worked decently well. This most recent time was just me being a dumbass I guess. I thought the blue liquid could have possibly been honda blue coolant or something.
Old 07-13-2018, 10:32 AM
Fish Twig
tony_2018's Avatar
What you'll find is something that didn't belong on the water pump when you 1st installed one, almost every Honda water pump that year looks similar so there is no reason to say you don't know how a water pump from a honda civic suppose to look like.
Old 07-13-2018, 01:20 PM
LSteggyguy's Avatar
I've seen a lot of civic water pumps and they're really simple. This particular water pump is leaking from the weep hole, no doubt about it. The thing is that the big impeller is covering the seal, so there's no way for me to see the condition that the seal is in.
anyways, I ended up saying **** it and JB welded both weep holes closed, and now it's not leaking
Old 07-14-2018, 10:50 PM
on the record for anyone searching this topic- bad idea. weep hole leaking means seals have failed. failure imminent.
Old 07-15-2018, 06:37 PM
JRCivic1's Avatar
Yes, bad idea. Replace the pump.
Old 07-16-2018, 09:01 AM
LSteggyguy's Avatar
Yeah, I know it's not the best thing to do to JB weld the weep hole closed. But if the solution is replacing the pump, may as well do it later. The pump is quiet, nothing seems to be going wrong just yet. Why replace it now when I can do it later?
Old 07-16-2018, 03:01 PM
holmesnmanny's Avatar
the only one that works is K-Seal
Old 07-16-2018, 08:28 PM
Fish Twig
tony_2018's Avatar
holy ****, jb weld the weep hole. Read something new every yr.
Old 07-16-2018, 08:46 PM
LSteggyguy's Avatar
Hey, well it worked. Holding pressure great, no leaks what so ever, water pump is still quiet.
Old 07-16-2018, 10:11 PM
until it abruptly stops working great.
Old 07-16-2018, 10:35 PM
Randolph's Avatar
this is how much a no name brand water pump is on eBay....you really can't afford a brand new water pump?
Old 07-17-2018, 06:13 AM
Fish Twig
tony_2018's Avatar
Let it go.
/thread
moving on.
Old 07-18-2018, 08:50 AM
h22a4sol's Avatar
Smh some people just want their **** to blow up. He'll be back in a week or so
Old 07-21-2018, 12:07 AM
crazyhorse2011's Avatar
and you made fun of me for my civic -_-
Rick1t
03-14-2016 01:30 PM
cstap
10-10-2013 06:34 AM
tony_yang
Honda Civic (2006 - 2015)
01-28-2011 03:49 PM
Champs32
02-14-2009 07:28 PM
CrazyKoreanCrx
08-23-2004 01:55 PM
Quick Reply: Does head gasket sealer wreck water pump seals?
