Garage cleanup - SSR, Hasport, Quaife, etc
UPDATE -- Make reasonable offers. Need to clear out soon due to some medical issues. Thanks.
Selling most of my stuff. I'll keep it updated as I keep cleaning.
1. SSR Type C's. 15x7 +42 4x100. Falken 512's 205-50-15. Original from early 90's, has some rash, paint chips, wear. Should clean up decent with a good cleaning. Comes with titanium extended lug nuts. SOLD...
2. Apexi N1 coilovers with ITR lca's. SOLD!!
3. Hasport EG/DC H22 mounts. 70a compound. Edge of rear mount chipped up from install/removal. SOLD!!
4. DSS 2.9 axles for H22 in EG/DC chassis. For use with factory hubs and good for 550 hp or so. $400
5. H22 Transmission with Quaife LSD. Had bearings replaced when lsd was installed but that was back in 2003 or so. Had slight 5th gear grind at high rpms's but went away with Friction modified fluid (Will include fluid). SOLD!!!
6. PRI Shift box, DC short throw, Greddy ****, with H22 shifter cables. Mounts under tunnel, cnc machined by PRI, pretty rare piece. $250
7. KS Tuning balancing shaft delete kit with pan gasket set and KS tuning timing tensioner. Brand new in box. SOLD!!!
8. MSD setup with battery relocation. 6al with blaster coil, b-series obd1 LS distributor with msd cap and wire, aluminum tray (where oem battery goes) with phoenix gold cables and cutoff switch to rear of car. SOLD!!!
9. Momo wheel with new hub for EG/DC. Worn with thumb wear and cracking. $75
10. Hondata s200 P75 ls ecu. NO BLUE BOX or CABLE! Ecu w/chip only. $60
11. Topspeed B-series 4-1 header. Damage on bottom as in pictures. $20
Thanks for looking and I will be adding stuff with pictures as I keep going through boxes. Feel free to PM me or text @214-766-2517. Located in Southbay Torrance/Redondo Beach.
Brandon
Brandon
The Birdman
07-19-2007 06:36 PM
