OVERHEATING!!! :(
OVERHEATING!!! :(
Hi, heres roughly what happened so far ill try to include as many details as possible.
Car is 1991 accord wagon f22a6 / 2.2L
Car overheated one day while driving (almost max temperature.)
Topped up with water, overheating issue went away.
Problem came back a few weeks later, replaced thermostat.
Problem went away for a few days.
Problem came back again, removed thermostat (running with no thermostat).
(also noticed at this time that when i started the engine with the rad cap off, water burst out the top of the rad(maybe because plugged or backed up?(no signs of water mixing in oil or visa versa)))
Problem came back with no thermostat in, seemed like water was bubbling to top but didnt seem like flowing.
Replaced water pump / timing belt. issue went away for a few days. came back.
Now im thinking something is plugged i guess?
I'm thinking I can turn over the car by hand and see if the water will flow? (im at the point where im only working with water since i constantly have to keep draining it and its summer)
Where would be the places to check if its plugged, the radiator itself? How do I check if its flowing?
Any tips would be great! thanks all.
Re: OVERHEATING!!! :(
Because there is really no sign at all that the fluids are mixing either way.
Ummmm, so the fan closer to the drivers side is the only one i've ran since i bought the car 2 years ago... I drove in much hotter weather than now without the other fan. The bigger passenger side never ran and it never had heating issues that way for 2 years =/
In terms of what the fans are doing during the overheating issue.. im embarrassed to admit i didnt even check the fans xD... even though i replaced the water pump lmao.
Hi you solved my problem. the one fan i was relying on isnt running... it was running yesterday and today its not so seems like intermittently doesnt run for whatever strange reason. thanks, you should be able to get some tax credit back for community service helping the mentally challenged. thxthx
When I watch the coolant while the rad cap is off it constantly bubbles, little bubbles... it never fully bleeds the air out which makes me guess that somehow air is leaking into the cooling system? which would explain maybe why it slowly builds up to the point that too much air is in the system and my car overheats, or a pocket of air gets near one of the sensors...
Im not sure if that theory is even possible, since no coolant is leaking out i dont know how air can go in without coolant coming out
Yeah these little bubbles probably mean my head gasket is blown and its exhaust gas i guess.... should i try one of these head gasket fix things that you poor into the coolant? doing the head gasket is about the value of the car itself, lol
I saw there is a test kit you can put in the top of the rad with some blue liquid, if it turns yellow it means exhaust is leaking into the cooling system, in other words head gasket. Maybe I should try that kit?
Maybe I can use that gasket repair liquid thing... and redirect the flow of coolant so its not going through and clogging my heater core. might be worth a shot i guess.
passenger side fan never runs because i took the fuse out.
drivers side fan seems to have a mind of its own when it wants to run... i was overheating yesterday and it decided that time it didnt want to run.
You also need to get that other fan working.
The next time it starts to overheat, with the fan not running, turn off the car, turn the ignition to on without starting the car and jumper the fan switch at the thermostat housing with a paperclip. If the fan turns on then the fan switch is bad.
Well, thanks I think the head gasket is done. I'm seeing one totaled 1994 EX-R for $500 with 110k on the engine. Might be worth to buy that and swap F22B1 in place of my F22A6... but dont know really if its compatible to swap those or whatnot so ill probably make a new post here.
dlenoxx
12-02-2010 12:05 PM
