Want to Buy Want to Trade/Want to Buy
WTB B Series Vtec Rocker Arm Assemblies...
Old 04-18-2018, 06:37 AM
simjosh's Avatar
Default WTB B Series Vtec Rocker Arm Assemblies...
I unfortunately need a full set of b series Vtec Rocker arm assemblies.
***Also looking for some Stock hydraulic style LMAs for B series...
Please let me know the cost to ship them to Baton Rouge LA 70809.
I would also appreciate close up pictures of each assembly to see the condition of the set.
Any help in obtaining this would be greatly appreciated! PM or reply to post for contact information or email to supply photos. Any questions let me know and I'l get back asap.
Thank you..
Old 04-18-2018, 10:16 PM
*JDM*Ej8*'s Avatar
Default Re: WTB B Series Vtec Rocker Arm Assemblies...
I,have some 5093780330 from an itr
Old 04-19-2018, 06:11 AM
simjosh's Avatar
Messaged.
Old 04-19-2018, 03:55 PM
simjosh's Avatar
Just sent in money for Rocker Arm Assemblies..
Should just be looking for the old school style LMA's now.
Big thanks to *JDM*Ej8* for the rocker arm purchase.
Old 04-19-2018, 04:05 PM
Klasse's Avatar
Curious why you're after the hydraulic over the spring type LMAs? Everything I read said go for spring? Although B18C Type R is supposedly not superseded to spring type by Honda while other B series are.
Old 04-19-2018, 05:04 PM
simjosh's Avatar
Good story...
Manufacturer of my aftermarket camshaft said they've had "some issues with spring style lma's"..
After 400-500 miles I went to do valve lash check per mfg instructions and noticed almost every vtec lobe wiped clean of oxide coating... Didn't know wtf that was about. Contacted them and was told the above... Supposedly they were designed around oem style and some but not all have had issues (assumption from wording) when using spring style.
As you have read... (about spring style vs hydraulic) that didn't make any sense, yet it appears somewhat accurate...
- Spring style didn't allow for enough clearance which results in too tight or no gap which creates an oiling issue - paraphrased but that's the gist of it...
So I need all new rockers since my vtec pad is scuffed slightly and cam mfg might be able to polish what I got on the lobe.. Not sure where it'll go just yet...
Old 04-19-2018, 05:47 PM
Klasse's Avatar
Interesting, thanks. Possibly the higher lift/duration/whatever of OEM Type R cams is also why Honda says to use hydraulic.
Old 04-20-2018, 05:28 AM
simjosh's Avatar
Not completely sure. I'll figure it out eventually though! Definitely will not make the same mistake twice either!
Old 04-20-2018, 07:58 AM
eh2_Trav's Avatar
I have a set of hydrolic lma's. Shoot me a text 760-284-2683 and I can get you some photos.
Old 04-20-2018, 10:25 AM
simjosh's Avatar
Looking for GSR / ITR lma's specifically .. .. Recommended
I believe some 99-00 B16's had the larger lma - those might do also.
Old 04-25-2018, 10:59 AM
simjosh's Avatar
Unfortunately I may still be in need of B Series Rocker Arm Assemblies... My last purchase has gone MIA.
Anyone with B series Vtec Rocker Arm Assemblies please message/ reply back with pictures and pricing.
*All payments- will be made with "buy a good" transaction.. please account for the percentage payall will deduct****
Thanks!
Old 04-25-2018, 02:37 PM
Rise VTEC's Avatar
Thanks!
sorry to hear that. I have a full set from an ek9. I'll pm you pics.
Old 04-27-2018, 03:19 PM
Undrboost's Avatar
Good story...
did this happen with a GSC t1 camshafts? I’m just curious.
Old 04-27-2018, 06:11 PM
simjosh's Avatar
Doesn't specifically matter imo. I messed up.
I've received two VERY different opinions from two reliable sources. When I find out the most likely cause or causes I'll update any relevant threads so that others don't overlook my mistakes.
As for the spring lma.. hypothetical issue is "lma not allowing the pad to fully disengage from the lobe".
- "lma doesn't allow the lobe to swing and keeps constant pressure on the vtec lobe and rocker pad when on secondaries"
So when I get cams back I'll rotate and check with a spring and hydraulic lma so I can see and feel the difference...
Old 05-04-2018, 09:36 AM
simjosh's Avatar
Still looking for some Rocker arms... Last purchase had USPS issues and came empty....
Vtec B series rocker arms - please no scuffs.
Thanks!
(Will be requesting UPS shipping quotes in future)
Old 05-04-2018, 08:56 PM
cruizinmax's Avatar
I have a set of rocker arms and LMA's if you want them. Shoot me an offer.
Old 05-05-2018, 04:15 AM
simjosh's Avatar
PM'd Thanks!
DC2Mex
05-18-2015 11:36 AM
dirtygsr94
07-17-2007 10:29 AM
SRBB6
05-23-2006 06:48 PM
doubleA
09-18-2005 01:01 PM
Quick Reply: WTB B Series Vtec Rocker Arm Assemblies...
