Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2007 Acura TL Tensioner Issue
Old 03-06-2018, 11:40 AM
bank2me's Avatar
Default 2007 Acura TL Tensioner Issue
Ok guys so I wanted to replace my serpentine belt and tensioner on my 2007 Acura TL base 3.2 I get the Gates kit through Rockauto kit #ACK060841. Which is the tensioner part #38332. And the belt #k060841. Well the problem I have is that on the new tensioner pulley, the "bearing cover" does not fit into it. But fit just fit just fine on the old pulley. Looking at the old vs new pulleys, the new one looks wider. So I tried bolting it on with the original bearing cover(spacer) and it makes a grinding noise. Then I try with just a regular "O" shaped spacer and I go to start it and it still makes a noise. Any ideas? Btw I haven't been on here in a while. I used to go in the Acura Integra page on here and post because I had Integras years ago. Its good to be back in an Acura!!
Old 03-08-2018, 10:52 AM
bank2me's Avatar
Default Re: 2007 Acura TL Tensioner Issue
Nobody has had an issue with the Gates tensioners on their TL?
Old 09-23-2018, 07:48 AM
b18a1crxsi's Avatar
i have a gates tenioner and belt on my car now and works fine for me. honda/acura does have a tsb on trimming the timing belt cover to prevent noise from other brand tensioners.
theres a plastic bushing that comes behind the bolt hole on the gates tensioner. it holds the bolt from sliding out while installing.
i would make sure that bushing didnt fall on and wedge itself between the tensioner and the mounting surface.
i just did my timing belt/ water pump 2 days ago and had to remove my tensioner, i reinstalled everything and mine is quiet.
the tsb is #08-049 if you google it, should be able to find on honda website
Old 01-08-2019, 04:23 AM
bank2me's Avatar
UPDATE: Sorry for no update on my thread. I have since returned the new gates tensioner and have picked up a new tensioner from the Honda dealership instead. Put it on... no problems. Bolted right up just like the original and I was good to go. But yea I can see what you mean about the aftermarket tensioner hitting the Timing belt cover. I just figured eh screw it, I'll just buy an OE replacement and not have to F with it.
93SIVtec2112
07-03-2011 03:44 PM
92coupe
12-17-2008 12:08 PM
GSRpoweredSI
06-20-2007 01:13 PM
ekferio
07-21-2006 06:49 PM
Quick Reply: 2007 Acura TL Tensioner Issue
