Rd1 lifted turbo build
Found this crv in terrible shape with a blown motor and 4th and 5th gear out in trans. Picked up a jdm b20b. Found the 5 speed rt4wd transmission and shifts smooth, went with garbage clutch which I will be changing very soon. Passed smog in Cali ripped it apart the same day.
My ebay/crap part list: I've been collecting and now installing excuse the mess
Mishimoto intercooler
Dewhel blow off
Amazon wastegate friend had, getting tial soon
ac/ps manifold from Amazon
half radiator and fan from .... Amazon lol
racetronix 440 injectors
s300 hondata with boost by gear only component I didn't go cheap on
cheap ebay turbo I got from a friend, will get more info on it next post
basset 15x7 picking up 215 75 at for them next week
2" spacers and 1.5" spacers
b18b intake manifold
plasti dipped in I'm my garage, masked off my other vehicle s and still got everywhere nightmareee.
hardwired a Samsung tab e 9.6 to a voltage regulator then to radio wire, removed battery. 4.7v did the trick.
Taking it to get downpipe made and then I'll post some pictures and more info
Dewhel blow off
Have a bull bar for a 86-06 TJ. Cutting all the plating off and welding it on and adding 2 bars to the bottom and a skid plate today post pics soon.
needing help with a base tune ( or at least my injector dead times and volts)
01D030B racetronix.. help appreciated
05 civic skunk2 short throw shifter cup with shifter extender. This is a must imo for 5 speed owners. Without the extender it feels much shorter.
Tablet now connected to bluetooth transmitter for obd2 and another for equilizer then in the 2 amps. Sound doesn't seem to get loud enough might abandon it and just use tablet for torque pro and hondata
Re: Rd1 lifted turbo build
Starts up first try and sounds healthy, didn't expect it to since this is my first turbo install. Hondata question: connected to laptop light blinks red in ecu, I get info tab and able to register but can not get upload to turn (un grey).
solved: hondata chip wasn't set right
Where did you get the 05 civic skunk2 short throw shifter cup with extender?
I also find the stock stick setup a little manky, I think even just an extender will help, what thread size/pitch does the stock CRV stick use?
the extender is a 3.75" off Amazon it was less than $10
both off amazon
Thanks mate, I struggle a bit with shifting my CRV, the longer than usual throw does seem to be an issue.
I find especially going from 1st to 2nd, I struggle to find 2nd.
How do you remove the stock gear ****?
I can loosen mine but its somehow connected to the vinyl shift boot so after turning the gear **** about 180 degrees it starts binding, I'm nervous of forcing it, does the gear **** somehow clip onto the shift boot?
as far as the **** I believe I just twisted it until it came off.
here's the shift boot I used:
15x7 basset wheels 3.75 backspace, 5mm hubsentric spacers on front.. 215/75/15 roadcruza actually pretty nice tires for how cheap they are. No rubs. After lift the front seems like it's much higher the 1.5" and rear looks lower than 2", but I like it. Next step is install headlights, make a different bull bar (jeeps way too big).. tial wastegate.. and dunno tune. It's been a fun project and getting close to done enough for me
Not sure where to solder the temp wire so i might just pass on it. Temp gauge will not work but i have that with hondata app. Couple other things needed to be worked out but it 99% accuate to hondata appPut in new front axles. Need motor mounts and harmonic balancer and belts (ugh neverending).
https://m.youtube.com/watch?v=7Eo3Kb8Nm_k
Check engine, cruise and abs light stays on. Will probably cover the led. Looking at buying a parts crv with clean interior dash door panels and all.
Need to put these in, going to pick up to front lower tomorrow i see theres not much left of it. Ebay rear camber kit came in, theyre heavy so maybe worth it.
