Welder question for guys that have done their own exhaust
Old 01-20-2018, 06:13 AM
Stopsign32v's Avatar
Default Welder question for guys that have done their own exhaust
Would an Easy Mig 140 be a good welder for exhaust work such as cutting and rewelding/welding in mufflers? I'm a novice but have access to this welder.
Old 01-20-2018, 06:19 AM
-Intl Steve Krew
Caoboy's Avatar
Default Re: Welder question for guys that have done their own exhaust
Yes, it will work.
But it really depends on the type of materials the mufflers/exhaust piping are.
Old 01-20-2018, 06:55 AM
Originally Posted by Caoboy
Yes, it will work.
It will probably be aluminized steel piping with magnaflow mufflers
Old 01-20-2018, 06:59 AM
-Intl Steve Krew
Caoboy's Avatar
It'll be fine.
Mild steel or stainless steel mufflers?
Old 01-20-2018, 07:48 AM
It'll be fine.
Not sure yet. Maybe either or. Where's the concern I feel you are holding back with? lol
Old 01-20-2018, 08:13 AM
-Intl Steve Krew
Caoboy's Avatar
Well you'll want to run 309L wire and trimix gas if you're welding SS mufflers to steel exhaust piping. Basically any stainless to carbon.
Other than that you can just run er70 and regular ole argon/co2 mix if it's just steel to steel.
Also learn to tig weld if you want to charge more
Old 01-20-2018, 08:33 AM
Dark_Teg's Avatar
^^^This guy knows whats up....
Old 01-20-2018, 08:48 AM
-Intl Steve Krew
Caoboy's Avatar
I get down with metal just a bit
Old 01-20-2018, 09:24 AM
LOL so I see there is much I need to learn with welding. You lost me at 309L forward. I'll have to google "mig welding for dummies" I think.
Thanks for the help! Sure will beat having a shop do it and charge me $300.
Old 01-20-2018, 09:27 AM
-Intl Steve Krew
Caoboy's Avatar
309L is stainless wire. It's used to weld stainless to carbon(mild/black steel)
You can't weld stainless with regular er70 (mild steel) wire. Well, you can, but it is definitely going to rust and crack.
Old 01-20-2018, 11:20 AM
Awesome, that's good to know! Thanks a bunch
Old 01-22-2018, 07:56 AM
Pro-SeriesFab's Avatar
Honestly, unless you are doing welding for a living, the basic sub $400 MIGs are just fine.
There isn't much to a generic 110v MIG . . . sometimes you get some QC issues from them being made overseas but they can be fixed most of the time.
I still have my northern tool 110v MIG I bought years ago (4-5?) and it still runs like a champ. It's a great welder for some guy who needs a little crappy muffler on and you don't have the time or ability to throw the car on a lift. I just did some high school looking kid's e36 he wanted the rear muffler at the bumper chopped off of and straight pipe welded in. Didn't have the space in the shop at the time so rolled the northern welder out, sawzall the muffler off, fit up the pieces of straight he got from autozone, and 30 minutes and $40 later he was on his way.
Old 02-18-2018, 08:13 PM
the171's Avatar
Ive had this same welder for years. This little welder is great and can do alot for its size. For exhaust its perfect, B heat and about 2 feed wire speed works good. Mild steel sucks never use that stuff. Itll be rusted and broken in a year. Aluminized is better and can last. Obviously stainless is the way to go. You can get very good results which will last years with just basic flux cored wire no gas needed.
IntegraType-R
09-02-2008 07:45 PM
See Are X
Welding / Fabrication
07-16-2008 10:19 AM
BlueShadow
12
06-19-2005 04:27 PM
dawrenn
14
03-12-2005 09:22 PM
RCautoworks
10-18-2004 10:37 PM
Quick Reply: Welder question for guys that have done their own exhaust
