Switching from crome to Neptune
hi guys
I have finished installing turbo kit on my h22 lude. Currently i am running P28 chipped with h22 basemap crome tuned. I would like to get my car tuned with Neptune, What are the things required to do this?
Re: Switching from crome to Neptune
going to a tuner? they should be able to handle everything from where you are forward as far as the ECU.
amusing the turbo kit had everything it should
Welcome to HRTuning ? Home Of NepTune
I had a ITR basemap on my JDM P30 running on eCtune. I'm in the process of switching it to Neptune. I have been in contact with Chris Harris over at Xenocron Tuning Solution.
Chris told me I need to discard the chip and install the Neptune RTP. Then I will need to load a new basemap through Neptune and the Demon RTP onto the ECU.
The Neptune RTP becomes the chip as far as ECU is concerned.
This is very important there are (2) version of the RTP. Make sure you get the right one for USDM ECU you need RTP Demon 2 and for JDM ECU you need the RTP Demon 1.
I thought that distributors/tuners of neptune could do chip burning but I could be wrong. If so then yes you can pick up a demon 1 or 2. I actually am selling a demon one in the for sale section btw 😉
If you want to move to Neptune as a chip, get in touch with your local (or nearest) Neptune dealer. It's just remove the Crome EEPROM, do tuner stuff then write a new (or reuse) EEPROM memory. If you are talking about Neptune RTP (With a Moates Demon), then remove your chip and insert your Demon. Then get it tuned.
