95 Civic Starting Issues
Old 10-22-2017, 12:34 PM
CustomBuilt's Avatar
Icon5 95 Civic Starting Issues
Looking for some ideas. I own a 1995 Honda Civic DX with a D15 Automatic. It has trouble starting after a good day of rain or if was humid overnight, trying to start it in the morning. It will crank & crank & crank. Almost every time it EVENTUALLY will fire up. During this cranking process once I hear the click from the dash, it fires up. I have checked distributer/cap, spark plug wires/plugs, coil, air intake/filter, battery, alt, and I even replaced the Main Relay. I was thinking that maybe it could also be the starter relay. I would really appreciate any ideas at this point. It has been a frustrating 2 years with this issue.
Old 10-22-2017, 04:42 PM
tamboo's Avatar
Default Re: 95 Civic Starting Issues
here's a line up of the usual suspects:
Honda Acura Essential Electrical Repair Website. Troubleshooting Main Relay, Coil, Igniter, etc.
Old 10-23-2017, 03:51 PM
Outrun's Avatar
Moisture seeping into ECU or bad capacitors in ECU?
Old 10-23-2017, 05:57 PM
Megalodong's Avatar
Originally Posted by CustomBuilt
During this cranking process once I hear the click from the dash, it fires up. I was thinking that maybe it could also be the starter relay.
Next time it does this after a rain try spraying WD-40 on spark plug wires and distributor cap before starting.
Read this: SOLVED: Does 1998 Honda Civic have a starter relay? If so, - Fixya
Read this: https://honda-tech.com/forums/honda-...rains-2971346/
Old 10-28-2017, 04:55 PM
bloomin's Avatar
I would bet 80% chance it is failing electrolytic capacitors in the ECU. As humidity increases it changes the resistance in the component and will delay fuel pump circuit prime. this is a common failure for Honda civic and accord from 91-97.
dtwtouch
03-14-2017 02:21 PM
Stephen122193
01-03-2016 07:19 AM
hacker4991
06-29-2015 12:44 PM
chrisff521
36
10-20-2012 11:28 AM
vladiscoolej1
15
10-23-2010 06:55 PM
Quick Reply: 95 Civic Starting Issues
