The "all types of action" Turbo Civic build...11 sec Stock B16 + some...
Old 07-01-2017, 06:14 AM
Autoworks's Avatar
Default The "all types of action" Turbo Civic build...11 sec Stock B16 + some...
Hello H-T. Forgive me in advance, it's been a while since I've attempted to do one of these.
The Car: 92-95 Civic Coupe
The Motor: Currently a 100% internally stock B16 w/ unknown mileage
The purpose: Fun street car, roll race car, "street class" drag car.
Original Goal lists:...be competetive, and go 11s on the stock motor (at this point that has been achieved)...on to Goal #2 (to be addressed later in the thread)
A big "kicker" here (which will make sense later) is this car has NEVER been on a trailer. It's driven to and from where ever it goes.
The car belongs to a good customer of ours, Scott. This build has actually been going on for maybe a year and a half now. I thought I'd do a thread on it as it's something a little different, and may answer a lot of basic inquires that pop up in the forums. Scott brought the car in, sat down, and we went over the goals; both immediate and long term. The car was to be and has been handled in phases more or less. He does his research, homework, asks questions, listens and gets good results...what more can you ask for there. The forced induction/fabrication/fueling/parrts delivery was to be handled here. The suspension and whatever else that can be bolted on, or walked through was to be done by him.
So here we go: When he picked the car up, the swap was already done. It as most had it's "short comings " and short cuts taken, but nothing that couldn't be easily fixed/addressed.
(a few parts were picked up while it was NA that would work throughout the build process...excluding the air intake)
(I just realized how long this build has been going on while looking for photos, the Na pic is early 2015). Sept 2015 the tear down began.
Fueling: The car was going to be run on E85 so we went with:
-Grams 1000cc injectors +320lph in tank pump
-6AN fuel feed kit from tank to rail w/ inline Aeromotice filter
-Aeromotive regulator w/ Skunk2 composite rail
-tuned on Hondata S300 V3
This would easily handle what would be thrown at it.
The kit/bay layout was designed specifically for the build as well. We went with (what was at the time) the new T4 internal gate Turbonetics turbine housing which had been something we had been testing. The turbo is our BB T-GA 6157 turbo option. This is a unit that I knew would deliver the needed power & curve while still being able to make the future goal further down the road. A mini ram was built to accomodate it, along w/ the rest of the turbo kit.
Old 07-01-2017, 06:25 AM
Autoworks's Avatar
Default Re: The "all types of action" Turbo Civic build...11 sec Stock B16 + some...
The car was street tuned. It later went to a Monster Roll Event (roll race), was the only FWD car there, and won the event.
Some things were learned, some things needed to be addressed (trans and exhaust).
The turbo setup was run back through an exhaust that came on the car originally; which was 2.5" "online auction" special-ish. The turbo was much happier when run as open downpipe. The trans that came in it also had a damaged rear mount, so it to was addressed by sourcing a GSR trans and installing a Quaife LSD. While addressing the exhaust, the decision was made to just run an up pipe. The turbine outlet was 3.5" so to help gain adequite clearance, we opted to go a different route on the manifold as well so that I could shift it over.
Old 07-01-2017, 06:35 AM
Autoworks's Avatar
The boost was dialed in more and the car went to it's first drag event last Nov, and made its first of several 11.9 passes (that goal met... 11.9@116mph)
Facebook Post
(I see that vid link isn't working, will address that)
A little ign breakup was becoming consistent so next up was to swap the car over to COP and also get some more suspension work tied in.
Added:
-Hondata COP kit
-Skunk2 spherical front LCAs
-Skunk2 Rear LCAs
(already in place not noted earlier was the Skunk2 Pro Cs and Full Race Pro Street bar)
I think we are caught up to now (2 years covered cliff note style). The car had something come apart in the harness, so the ideal solution was to replace it at this point being that it had already been chopped and screwed multiple times. A Wireworx harness was ordered. We also needed to get better boost control on the internal gate up top, so I contacted Tial and that is now being worked in for the next visit coming up!
Old 07-01-2017, 11:02 AM
Autoworks's Avatar
A quick shot of the fuel side
Old 07-01-2017, 12:20 PM
civic-steve-94's Avatar
Great to see other people using B16 power plants. I did a build on a friends B16 Stock block and valves, Has The go-autoworks T3 top mount running the turbonetics 6162 .63A/R exhaust housing. Made 410whp@16psi , havent had a chance to take it to the track but should be quick.
Old 07-01-2017, 01:32 PM
Casey's Avatar
interesting build for sure. glad to see some new posts on here as well from you and Rob
Old 07-01-2017, 01:55 PM
ls joker's Avatar
Awesome man. I glad you decide to make this thread. Keep them comin, long as the clients are okay with it.
Old 07-01-2017, 04:47 PM
boosted94gsr's Avatar
I like it. Thanks for sharing 👍
Old 07-01-2017, 05:33 PM
turbociv910's Avatar
reminds me of my old coupe. b16 was my favorite turbo motor out of the gsr and lsvtecs ive had.
Makes me want to do another turbo build
Old 07-02-2017, 04:56 PM
Bubbagump's Avatar
What catchcan is that?
Old 07-03-2017, 06:14 AM
Autoworks's Avatar
Awesome...I have a similar build in a GSR out in the shop now (built B16, Topmount kit, BB 6162)
Old 07-03-2017, 06:17 AM
Autoworks's Avatar
forgot you could multi quote...
Thanks man, hope all is well.
It's a task to do, but I'll try to keep this one up to date and going w/ info.
thanks man
I made the can specifically for him/this setup.
Old 07-03-2017, 07:22 PM
B and B's Avatar
How much is it making now?
Are 1000's gonna be enuff to feed it E85?
Duty cycle as it sits?
I wish I had one of those Skunk2 rails...For a long time now.
Old 07-04-2017, 08:40 AM
Autoworks's Avatar
The car will go on the dyno after it's next visit. It has been 100% street tuned.
Yes, it's been on E85 the whole time with the same fuel system listed.
Old 07-04-2017, 07:19 PM
JRCivic1's Avatar
Check the Skunk2 website right now... 25% off for the 4th of July... get one now while it is on sale !!!
Old 07-05-2017, 06:18 AM
nsxmatt's Avatar
Glad to see people still messing with stock B16's. I went 11.8's on one back in early 2000's on pump gas and a drag kit and a FMU lol. Those motors will take quite a bit of abuse!
Old 07-05-2017, 07:59 AM
ls joker's Avatar
Short stroke team!
Old 07-05-2017, 09:40 AM
No Jodas
ShinsenTuner's Avatar
I have a B16 long block laying around that could be of some use towards a future turbo setup. Yours is definitely an inspiration!
Old 07-05-2017, 10:07 AM
Balor_Gr's Avatar
Very nice !
**** i feel like a puss now . Im afraid to hit 300 on my b16 lol.
Old 07-06-2017, 04:27 AM
Autoworks's Avatar
awesome! This one has definitely taken a licking (knock on wood). There's something in store for the near future anyway JIC.
Short stroke team!
FTW
Thanks
Originally Posted by Balor_Gr
Very nice !
300whp now a days can be made so easily w/ very little "stress" on the motor.
Old 08-09-2017, 03:55 PM
ls joker's Avatar
Ever get that wireworx harness installed
Old 08-11-2017, 12:45 PM
Autoworks's Avatar
Yes, the car will be here in a week or so for some more odds and ends
Old 08-20-2017, 08:13 AM
Autoworks's Avatar
in for another round of goods
Old 08-20-2017, 11:29 AM
ls joker's Avatar
Woot woot.
No starting issues or electrical gremlins at all since switching over to the wireworx harness?
Old 08-20-2017, 06:01 PM
Josevti's Avatar
looks good, is amaizing all that power with stock internal....
Quick Reply: The "all types of action" Turbo Civic build...11 sec Stock B16 + some...
