Where does this plug-in? I believe it's IACV?
Old 06-28-2017, 03:15 AM
GameBoyeas's Avatar
Default Where does this plug-in? I believe it's IACV?
Hello,
I have a 1990 Honda EF STD; originally had the D15b2 engine which was swapped to DOHC ZC which has now been swapped to D16A6.
Does this component plug-in into my current harness? I can't seem to find anywhere for it. I heard a rumor this component is just for Si vehicles.
Old 06-28-2017, 05:59 AM
jlicrx's Avatar
Default Re: Where does this plug-in? I believe it's IACV?
the component on the back of the intake manifold is the Fast Idle Control Valve (FICV) which is only found on the 89-91 D16A6 - it should have 2 wires, one black/yellow and one solid blue - the black/yellow is power which can be connected to the black/yellow at the purge cut-off solenoid on the firewall - the blue needs to run to ECU pin B2 on the PM6 ECU - the FICV function is to boost the idle a little when the engine is cold and the ambient air temperature is below 14 degrees F - the engine will run fine without this component being connected and will not result in a CEL
by the way - it appears that the vacuum line from the throttle body to the MAP sensor is not connected and the vacuum port for the PCV valve is capped off
Old 06-28-2017, 06:05 AM
GameBoyeas's Avatar
Thank you for all of this information! If the car is a warm weather driven car only, should it be okay to just put a block off plate in place? Does it hinder anything else? Thank you.
Old 06-28-2017, 06:09 AM
GameBoyeas's Avatar
Thank you for pointing this out! I haven't attached the line yet though as I'm moving stuff around in the engine bay. Also PCV is capped in my application as I am running a catch-can setup.
Old 06-28-2017, 06:15 AM
jlicrx's Avatar
you could put a block-off plate on it - just make sure to seal it really well so that you don't have a vacuum leak - cap the port at the other end of the big hose
Nisif
10-03-2014 02:39 AM
Nickhimself
12
06-03-2011 03:49 PM
ed3tsmith
01-26-2009 08:24 AM
mikex1021
04-12-2008 04:07 AM
jdmcrx_echelon
08-29-2006 12:33 AM
Quick Reply: Where does this plug-in? I believe it's IACV?
