The Shodan & Project GHOST!!
Hontoo?? Another Project? Hopefully this will make for an interesting project as this will be the last B-series Project for a while. Onto an F2K-series and K-series turbo project next year. Please wish me luck as I document. Edit - 2018. Things change & stay the same....
Teaser.
Stay tuned....
Teaser.
Stay tuned....
Re: The Shodan & Project GHOST!!
I cannot wait until I am ready to purchase a Reaper from you! I just hope it's within my budget with what I am doing over the winter...
Hello and welcome to my build thread. I have entrusted Mac to take this thread and make it something wonderful like he has done so many times before. As time goes on you will see some very interesting items that I know you will have questions for. I am prepared to answer them as best as possible. I'm sure that Mac will definitely have many technical specs as he always does. Its nice to have someone that I can literally call at anytime of the day and get info and support about my build.
I'm really happy with this build as of the last few weeks. I have had my run-ins with some unlucky gremlins along the way and have found a new "Network" of trusted people. We shall call these lucky people "My Man". "My Man" has knowledge and support like no others. Professional people doing professional jobs all the time and on time. This to me is worth more then the build and the end result.
Thank you. It was a hard decision to go with white. Its a horrible color to keep clean but the end result is an eye popper.
I'm shooting for 504whp. Its a number that I saw on another car on a different platform with my same turbo. Most likely it will not be that but its a goal for now. More then likely I will be around 450.
Thank you! Pictures will be on the way. Info is being compiled and a master list will be ready by weeks end.
I like how Mac is calling this a "Reaper".
I think that we will have to talk about a new name change to the turbo.
Thanks for the comments. Please ask questions. If you don't ask, then who will?
This is a GT3584R "Reaper" made from a GT3582R in a .63A/R T31 4 bolt that used an older styled Anti-surge compressor cover. The unit was originally used, and was refurbished to accept the newer wheel. Had I not been able to clip the turbine wheel, it would have been a lost cause.
The GTX is an 11-single bladed setup, while the GT3584R Reaper is a differentiating 6 spoke splitter-bladed design.
I'll give a bit more detail soon, k?
Just a tiny little small update. I picked up the motor yesterday. OMG it's sex on an engine stand. I mocked up the manifold, turbo and downpipe. We snapped a few picks and did a small video. Your going to have to wait for Mac to upload them as he used his cameras.
isnt the gt series the gt series because of the exhaust wheel? is that just a really old gt35 before they had their own exhaust wheel?
what does clipping the exhaust wheel accomplish? i know dsm guys used to do it back in the day, havent heard of people doing it recently
Mac is the man! You went to the right guy to get **** done. Just be careful of that crazy english bastard over there. lol
The initial "Video" of the engine when he picked up the engine is pictured below. under the video are the specifications of the engine. Please note that not all parts me neither recommended by me or J3573r. This was from the previous "builder" before going to Autowerks Motorsport. J3573r decided to just keep what he had an not try to resell and change out.
This project was put on the back-burner for a while because of the fact that the engine needed to be inspected and cleared by Autowerks chief mechanic Andy N. He found several issues that would have proven catastrophic if not at least costly had he not performed this inspection. Once this check was performed, he completed assembly.
Specifications of the engine. Please note, some of these parts are controversial and not of our original design
B18C1 - Engine Block
*PROBE PISTONS -81.5mm 10.47:1 Stock sleeves
*PROBE RODS- similar to Eagles
*ACL Bearings using a micrometer to confirm measurements
*ARP Head studs
*ARP mains
*ARP Rod bolts for PROBE rod replacement
*ARP Crank pulley, clutch & Flywheel Bolts
*OEM GS-R Crank 87.2mm
*OEM P72 Head Gasket
*MOROSO 5QT Oil Pan
*Gates High Tension Timing Belt
*OEM GS-R 22T Water Pump
*OEM GS-R Oil Pump
*B&R Fittings Catch can and water line kit
*Clutchmasters FX400 -
*EXEDY 12lbs Flywheel
Cylinder Head
*GSC T1 Camshafts 1-25-2013
*TODA RACING CAM GEARS
*SUPERTECH FULL VALVETRAIN (DR Series)
*SUPERTECH Flat-top NITRITE-TREATED VALVES
*SUPERTECH VALVEGUIDES
*"3-Angle" Valvejob
*Skunk2 Alpha 70mm TB
*OmniPower 4bar Map Sensor
*OEM TPS sensor
*SKUNK2 PRO1 Intake Manifold
*BDL Fuel Rail
*BDL Cam Seal
*BDL Fuel Pressure Regulator
Forced Induction Components
*Spoolin' Performance Quick4 AC Exhaust manifold
*Spoolin' Performance 3" 4 Bolt Downpipe
*TiAL 38mm MV-S Wastegate 11.75psi wastegate spring
*TURBONETICS "Godzilla" Blow off Valve
*Go-Autowerks 2.5" Intercooler Piping -
*Garrett Single Back Door 20 x 10.5 x 3 Intercooler Anodized
Turbocharger
*STC TR3030R "VelociRaptor" Turbocharger
*T31 2.5" 4 bolt turbine housing .63A/R turbine housing
*ARP Head studs
*ARP mains
*MOROSO 5QT Oil Pan
*OEM GS-R Oil Pump
Cylinder Head
*"3-Angle" Valvejob
*OEM TPS sensor
*BDL Fuel Rail
*BDL Cam Seal
Turbocharger
Interesting manifold, Is that angle of the center section ok? i know there is a certain degree before its an issue just nto sure how much.
Silly me, i thought he might have read something i posted up. I didnt quite get the "over there bit"... So now i know how you know what real "crisps" are . He,he,he...
Did it cost a lot to get that intercooler anodized if you don't mind me asking ?
Here's an example of one of the Garrett ones done
Thanks for the info & picture. I'll bear that in mind if i ever want it done. How well do those Mishimoto intercooler work compared to a Garrett equivalent ? I'm going to need a better intercooler for the forged block that i'm building i think. I'll pm you sometime in the future about that though if you don't mind.
