***Official All-Motor Stock Sleeve B20VTEC Thread***
Re: post ur all-motor stock sleeves b20vtec builds (b20vtech)
84mm, 12.5:1. .5mm os ferreas, toda b int cam, itr exh. also tried the stg 3 comp exh cam. toda springs. je pistons, eagle rods, arp everywhere, jg intake mani, dc 2.5 colletor header, bbk70mm tb, aem ems, 255hp walboro, holley fpr, 31lbs inj, act 6puck. abused for 42,000kms then i pulled it apart. best et was 12.71, high mph was 108. 92 hb weighed 2200lbs w me in it. very consistant, 2 of the last days at the track made it around 20 back to back consecutive 12 second runs. the car got way faster after this but never made it back to the track, or dyno.
itr trans through 4 gears, with 20 and 22" mt
initially no, i ran those times on a stk p72 and also jdm p30. stock limiter and didnt idle like stock until the aem ems, i used dynomaths and ran slightly better timeslips with a worse cam setup, got it all sorted out with way more power everywhere but never did go back to the track.
no idea of whp, id guess at 200 or so. datalogging and dynomaths good enough for me. besides, most peoples dyno plots up here in vancouver B.C. read high by like 15-25%
Re: post ur all-motor stock sleeves b20vtec builds (GIZZ - EXV)
84.5 stock sleeve 11.5 comp wiesco piston, eagle rods, gsr portflow head, skunk2 manifold, skunk2 stage 2 cams, hondata , anr header, stock gsr tranny.
The motor made 215hp, 150 lbs, went 12.80 in 94 teg, daily driven on pump gas!!!!
It lasted a full year of daily driving and beating it up hard on weekends!!!
Moderator
b20
84.5 mm
endyne rollerwave 11.5 compression
eagle long rods
pnp b16 head
itr tbody
itr intake manifold
toda c's
toda header
power FC
220 and 160
this plot is same cept for the header it was JDM header but plot with toda header has more power sooner
84.5 mm
eagle long rods
pnp b16 head
itr tbody
itr intake manifold
toda c's
toda header
power FC
220 and 160
Moderator
Re: post ur all-motor stock sleeves b20vtec builds (faSHOwidIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faSHOwidIT »</TD></TR><TR><TD CLASS="quote">yes how long did they last before the sleeves cracked?</TD></TR></TABLE>
daily driving and drag racing is fine
road racing this will not work....i cracked sleeves on 3 b20s with stock parts at 84.25 with stock bottomend pistons out of the hole 15thou for mad compression...
Re: post ur all-motor stock sleeves b20vtec builds (chad)
woh, im sure u got plenty of experience with b20's.....how fast it goes on the track with the setup u got?
b20 84.5mm 11.5:1 JE
b16a head
skunk2 stage 3 cams
Rocket Gen 2 springs Omni Retainers
Megan Header
ITR LSD
rc 310
EVO 8 fuel pump 190lph
AEBS intake manifold
64mm TB
Tuned with Crome
214.9hp
147.3tq
2700lbs with me in it
b16a head
skunk2 stage 3 cams
Megan Header
ITR LSD
rc 310
64mm TB
Tuned with Crome
214.9hp
147.3tq
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote">woh, im sure u got plenty of experience with b20's.....how fast it goes on the track with the setup u got?</TD></TR></TABLE>
never got it to 1/4 mile....
that engine is for sale...has 100 miles on it!!!!!!
Here is my setup
B20z Short Block
B16 Head Mild Port And Polish
titanium springs ansd retainers
GSR Valves
GSR Cams
TWM 50MM ITBS
Prelude Injectors
Custom Header Tech Header with 3" collector
Gutted 3" cat
3" thermal catback
P28 ECU with Hondata S200
WHP 212.6
TQ 165.5
B20z Short Block
GSR Valves
GSR Cams
TWM 50MM ITBS
Prelude Injectors
Gutted 3" cat
3" thermal catback
WHP 212.6
TQ 165.5
Re: post ur all-motor stock sleeves b20vtec builds (mxpx035)
something doesnt seem right. i mean not to be rude or anything but there are people with VERY similar setups making 240hp, so what is the difference?
Moderator
Re: post ur all-motor stock sleeves b20vtec builds (KINGSOL18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KINGSOL18 »</TD></TR><TR><TD CLASS="quote">something doesnt seem right. i mean not to be rude or anything but there are people with VERY similar setups making 240hp, so what is the difference?</TD></TR></TABLE>
duh different dynos!!!!
his hp sounds good for the engine, its just over 10:1 with gsr cams. prolly didnt need the itb's, retainers and the 3" exh to do that but whatever.
Re: post ur all-motor stock sleeves b20vtec builds (JERK ONE)
well i am pretty sure the cams are killing me and it is running really rich, it needs to be re-tuned really bad just through it on the dyno to see what it would do because i have a a good hook up. and i just switched the exhaust and lost 30 whp all the way across the board. i installed a 60mm rsr exmag because i couldn't stand the thermal, now it sounds awsome but need it tunned even more but i belive i will get about 15 to 20hp out of retuning it so it would put me back to 200 which is perfect for my daily driver.
Show me some dyno graphs with the list of mods, because it seems hard to get 240whp on gsr cams. because i want to install cams and pistons but don't want to sleeve my block
b20b with gsr head
skunk2 valves
skunk2 springs
skunk2 retainers
skunk2 pro1 cams
skunk2 pro gears
block girdle
jdmshit intake manifold
exedy clutch and pressure plat
fidenza fly wheel (7.5)
not all together yet im working on it just want to get some pistons first may be some ITR pistons but ill keep you guys updated ill put it together in like 2 weeks and ILL break it in and take it to get tuned and ill let you guy no
skunk2 valves
skunk2 springs
skunk2 retainers
skunk2 pro1 cams
skunk2 pro gears
block girdle
i wasnt talking about your block specifically yours in fact your whp seems right<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxpx035 »</TD></TR><TR><TD CLASS="quote">well i am pretty sure the cams are killing me and it is running really rich, it needs to be re-tuned really bad just through it on the dyno to see what it would do because i have a a good hook up. and i just switched the exhaust and lost 30 whp all the way across the board. i installed a 60mm rsr exmag because i couldn't stand the thermal, now it sounds awsome but need it tunned even more but i belive i will get about 15 to 20hp out of retuning it so it would put me back to 200 which is perfect for my daily driver.
I was talking about people with skunk 2 stage 3 and 2 only making a little more than you. but it could be the different dynos i dont know why i didnt think of that
I have a b20vtec setup in my hatch.
b20z block, completely stock
b16a head with ctr cams and gears set to 0,0
skunk2 IM
b16 throttle body
3" shortram intake
ebay header, stock cat, apexi n1 catback
basically stock b20zvtec with ctr cams and boltons, street tuned with uberdata
ran it recently at the track, 93 hatch + interior
bfg g-force t/a drag radials 205/50/15
best time ;
R/T : .192
60' : 2.086
330 : 5.666
1/8 : 8.605
mph: 84.23
1000: 11.103
1/4: 13.233
mph: 105.77
Overall I am satisfied with what I ran, for a pretty much stock b20vtec, but I really just want to get that 12 second timeslip. Does anyone think its possible with maybe a better 60 foot and trying a few other things? Another thing is this was done with a LS tranny. I know people always say to get gsr or b16 but doesnt the LS have the same 1,2,3 gears? What would be the best transmission for me to get? Thanks
skunk2 IM
b16 throttle body
3" shortram intake
best time ;
R/T : .192
60' : 2.086
330 : 5.666
1/8 : 8.605
mph: 84.23
1000: 11.103
1/4: 13.233
mph: 105.77
