FS: Apexi POWER FC stand-alone engine management
MiG-21 superfan
Awesome and affordable fully programmable stand alone. The commander is a wonderful piece as you can monitor multiple engine parameters in real time with peak meter holds- knock level, water temp, intake air temp, rpm, injector duty, etc, etc...all this without having to have a laptop on all the time!
The FC features fully programmable 20X20 ignition and fueling maps, idle stability controls, coil voltage dwell, etc, etc, boost control capabilities (with avc-r or add-on boost controller), etc...
This is a STAND ALONE! you do not use an ECU with this, this IS the ECU. It's plug and play for obd2a, and up or down jumper harnesses can be had from boomslang fabrication for a similar price.
Can be tuned with Datalogit interface and software available from Datalogit, or by your local Power Excel tuning shop (recommended). You can also use the Commander Pro offered from Apexi, however this has limited function vs. the Datalogit or Power Excel software.
I can arrange for a b16b base map or b18c-R base map to be installed. Currently it has maps for a 150+ whp sohc vtec.
ITR guys LOVE this thing.
Price is <FONT COLOR="red">$450</FONT> shipped to the lower 48!
Re: FS: Apexi POWER FC stand-alone engine management (builthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch »</TD></TR><TR><TD CLASS="quote">SOLD!</TD></TR></TABLE>
damn good price. i would have bought it from you at that price for sure!
500hpintegra
08-22-2006 08:00 AM
