F/S ONLY ! : Complete part out ! Aftermarket and stock ! Engine and suspension !
Means of Contact (PM? Email? Phone?): PM
Just like the title says , Im starting to part out a 95 OBD1 GSR . The car is totalled and not salvagable at all , so dont ask for the shell. The car was hit in the front end. I will have the car back in my possesion in a day or 2 . The car is complete except for the front end as it is trash. But complete interior is their, suspension wheels, swap and all.
If your going to lowball me ............. dont even bother pressing the private message tab !If you dont like the price then make a reasonable offer, will be considered but not rediculous low ball offers, I will laugh at you and tell you to kick rocks ! You gotta pay to play ! These are all quality parts and no ebay bullshit ! If thats what your looking for then head over to ebay . Also I will not TRADE FOR ANYTHING ! Ive got the parts i wanted for my next car and thats it ! Im not getting antoher Honda , so dont bother !
Pricing will not include shipping or 3% paypal fees. So keep that in mind . Im willing to ship the head , but not the block or the rear disk swap, that will be pick up only ! Now onto the pictures !
ENGINE
OBD2 P72 '99 GSR Head , COMPLETE ! When I say complete it will come with everything you need ! Cams, cam caps, dizzy, valve cover, vtec solenoid, and all sensors -$600
Will not part anything from the head , selling as a complete head !
OBD2 P72 99 GSR Block , COMPLETE . Will come everything , all sensors, pulleys, clutch , flywheel , oil pan, and al brackets needed ! - $400
Will not part anything from the block , selling as a complete block !
I know the VIN is a bit hard to see , but I can supply that on demand for serious buyers. I just put that up to show that it has not been tampered with.
Comptech SS 4-2-1 Header w/o2 sensor. Header was used with a slip fit system. As you know these are hard to come by now a days and are pretty rare ! Over all good shape with no dents or dings. With some time and work , it can look like new, Ive done it a few times and it polished up to a mirror finish. If you want a pic of that I can. $300
Omni power 2.25" adjustable test pipe with all bolts and sections. used this with header above. - SOLD
OEM ITR Intake arm w/Apexi intake flange, bracket, bolts and gasket . Just needs a new filter. - $75
OEM OBD2 GSR TB with TPS and Map,( sensors work ) needs return springs - $70
OEM B16a2 TB with TPS and Map ( all working sensors ) - $75
P2R Throttle Body gasket w/ SS hardware for B-Series TB's -$15
ProStreet Online IM GSR Gasket ( same as Hondata ) - SOLD
NGK wires for GSR -$35
B&M Adjustable FPR mounted on OEM FPR - $45
OEM GSR FPR - $25
AR Black Alum Cam seal BN ! -$35
OBD1 GSR VTEC Engine harness w/ OBD2 Injector clips - $150
OBD1 P28 ECU with custom GSR maps done by IH8RICERZ here on Honda-tech.com. These maps are his own creations and worked pretty good ! 1st chip ( installed on ECU ) is a mild setup with simple alterations to : ignition, timing, fuel curves and setup for Intake/header/Exhaust/Intake Manifold ( for GSR ) . VTEC @ 5300 and redline is stock . 2nd chip is a race chip for the same mods , with more aggressive tune on the Ignition , timing and fuel maps. VTEC @ 5300 Redline @ 9200 ( i personally never ran the race chip and always used the mild chip ) - SOLD
2 OEM main relays - $40 each
Custom tucked Clutch line for INTEGRAS ONLY it "T's" off the firewall where the stock line runs to. Black with all fittings needed - $35
Dizzy goes with the head and not for sale seperately.
B-Series rear "T" bracket w/ bolts -$65
Side and rear B-Series motor mounts with Energy Suspension inserts ( rear and lower torque mounts ) all mounts and ES inserts and Energy Suspension shifter bushings with SS bolts. - $85 Selling as complete package !
RS Machine Polished Alum Dual core half sized radiator. Inlet and Outlet's are for B-Series motors, No leaks. I had this in my Teg will also include lower radiator mount . $100
OBD1 B-Series VTEC Injectors - $35
95 DB8 GSR Axle back -$100
Suspension
All Suspension parts will fit 94-01 Integras. 92-00 Civics .
Koni Yellow SP3 Shocks ( Neuspeed Edition ), Shocks have 5 positions to lower or rasie the spring perch, Neuspeed Race Springs , Ground Control Bump stops, Skunk2 Poly Top hat bushings . Whole setup has at most 5,000 miles ! This setup is ready to be installed as soon as you receive it ! I WILL NOT SEPERATE THIS SETUP, EVERYTHING STAYS TOGETHER . DO NOT ASK TO SEPERATE ! ! !
$650
AGAIN..... I WILL NOT SEPERATE THE SPRINGS AND SHOCKS... DO NOT ASK !
K-Sport rear lower control arms, all bushings are intact and in perfect working order with no cracks or tears - SOLD to H22ftw
Cusco ST front strut bar $100
Cusco ST rear strut bar $100
M-Factory 19mm rear sway bar w/ Prothane 19mm bushings and brackets - $125
Carbing rear lower tie bar - $50
Beaks rear subframe kit - $45
OEM GSR strut bar -$25
OEM GSR Front 24mm sway bar with OEM bushings and brackets - $35
OEM GSR Front 24mm sway bar with Energy Suspension bushings - $45
OEM GSR 13mm rear sway bar with all brackets, bolts bushings and end links - $65
OEM rear disk swap , complete ! [b]$250[/img]
Other misc. parts
OEM DB 95 taillights w/ a light smoke , all 4 pieces - $75
OEM DB 95 white side view mirrors with pigtail harness and inside covers - $50
OEM 98-01 Integra Radio/CD player with lower pocket -$50
OEM 95 GSR cluster , 133,565 miles - $50
Cluster trim - $25
ENGINE
OEM GSR FPR - $25
Suspension
$650
Other misc. parts
Cluster trim - $25
Re: F/S ONLY ! : Complete part out ! Aftermarket and stock ! Engine and suspension !
K-sports lower control arms - SOLD
everything needs to go ! I dont own a honda anymore and these parts are of NO USE TO ME ANYMORE ! Get this stuff out of my garage !
Thursday morning bump ! I need this stuff gone ! Its just collecting dust as it sits in my garage ! I know somebody wants some good quality parts !
Friday night bump ! I need this stuff gone , i need to make room for my new car !
Sunday night bump ! Still got plenty for sale ! buy buy buy ! I want alllll these parts gone ! I no longer own a honda , so this stuff is of no use to me anymore !
Memorial Day bump ! Thanks to all that serve and lets us have our freedom !
Any chance you would let go just the flywheel, clutch & pressure plate?
