CKF sensor GSR ITR B16 LOTS OF OBD2 ECU's
Hey I got F/S a Crankshaft Fluctuation sensor which fits on OBD2 oil pumps and is needed on OBD2 motors to pass smog $40
OBD2 ECU's
P2T OBD2b 99-2000 Civic Si B16 $50
P72 OBD2a 96-98 GSR $50
P75 OBD2a 96-98 LS $50
P2E OBD2a 96-98 Civic DX LX $30
P2E OBD2b 98-2000 Civic DX LX $30
Got a couple OBD2a to OBD1 jumpers Zerg Industries $40
OBD2 ECU's
Re: CKF sensor GSR ITR B16 LOTS OF OBD2 ECU's
hey how are you. I have a question for you. Is the P72 OBD2a 96-98 GSR a usdm ecu. If so do you happen to know if it will work on a 96-98 civic coupe. I'm running a stock b16b motor along with the stock ecu that the engine came with and I'm trying to pass immisions here in new york. In order to do that I need a usdm ecu and I also have to do the CKF Bypass Trick. Please let me know and I will send you the payment. Thank you.
http://hondata.com/techecuid.html Check out this link.
It's A03; A means usdm and 03 means manual trans.
As for passing emissions with a b16b not 100% sure. In California you would be out of luck since b16b never came in a us vehicle. I would say make a friend at shop and slip him some extra cash to "make it pass"
