B series PART OUT.. Rywire,ID1000, Fluidampr, RonDavis, OEM Window Visors
Couple price drops..
Most ALL items will be shipped Saturday mornings. I prefer to send UPS but will send USPS if you so desire. Generally speaking small items will go for $10 shipping and larger items are generally shipped for $50. (Just depends on the size more than the weight). ** I got a custom cut tool I use for torquing / crank bolt removal... Basically a 3/8 thick bar shpaed like " -----0 " with holes cut out for holding the Damper in place while dealing with the crank bolt.. ***** I do still have the outside pulley - It is not pictured as I didn't need it and kept it off... **** All items are for sale. I've got general pictures of everything and if some one would prefer a more detailed picture of a specific item... Just ask and I'll get it for you. So lets start with electronics first... (Pictures are at the bottom and there will be ton left off this list - it'll be added later as items on top are sold). ****Copied all the parts left together.. Was looking kind of difficult to perhaps see exactly what was left... ***** 1) Full RACE TRACTION BAR - $180 - Great condition .. EG / DC Street version (does not have middle motor mount) *** NOTE - I had a 3/4" spot weld tac'd in the middle to add rigidity to my custom radiator mount. So it just won't look as pretty as new. Does not affect performance. Make an offer or ask any questions! 13) Avid Racing Torque Mounts - $50 B series - used on 95 Teg 3) Summit Racing CDI (200mj) / Summit coil - $60 *new -only opened and verified that it worked* 11) Black OEM Fuel Filter Delete Kit... $65 *Comes with everything but the AN fitting for your fuel rail and you'll need a new compression olive for the hard line*** ----Fuel Lab (BRfitting Style) Fuel Filter shell - all you need is the filter that goes inside* All lines are -6an black hose / fittings. I've also got the fuel filter bracket used to mount. *extra 33 inches hose untouched included - prefect for fuel return line... 8) Greddy B18C1 Timing Belt - $50 - SHIPPED *Less than 1000 total mileage 17) SickBird Aluminium vtec Spark plug cover - $35 ****ENGINE STUFFS****** *This has about 4k miles - this stucker pumps some oil!** *You'll probably need to replace the friction material 4) ** This has Eagle Rods , 81.5 JE pistons and about 25k miles (Before tear down it still had 175-180psi compression and 10-15% leak down (for whatever this information is worth *This will have upgraded exhaust dual valve springs from an ITR. This head has about 1k miles on it since it's been milled (.005) and 3 angle valve job..Still perfectly flat and ready to use! Used as LS-Vtec / No Vtec solenoid / dizzy *1000 miles with titanium retainers and still practically new!* *These are the ones needed for your GSC T1's or higher seat pressure aftermarket cams 8) Oreilly Starter - $35 - - Steel construction Black with Black 75 durometer inserts - 3 post engine style *IN perfect working order... Never had a slip / grind / unusual noise... Filled with either Amsoil or Honda MTF *****Shipping on this WILL BE EXTREME! Custom heavy Duty Box - $15, Bubble Wrap to protect $20, Wood to line top/ bottom $20 - UPS Shipping anywhere from 120-180 (Billable weight 100-120 lbs) - - Trans weighs in at 88.5-89 alone and without ANY shipping materials. ***Missing stock allen head 1/2 plug for turbo feed (1/2 npt bolt head style brass plug currently installed) and 1/8 npt allen head stock plug. (can put a 1/8 brass plug in if needed)... This was important to someone else so I figured I would mention this for other interested parties...****** 11) Golden Eagle B series Oil Dip Stick - - $20 *roughly 3k miles* Again any additional or specific pictures needed please let me know and I will provide what you require within 24 hours. **I'll be taking a couple more pictures today and adding them in the posting. (Comes with mounting plate/hardware) *This was double crimped for the CDI box / Bypass and includes all wiring to Dizzy... I ended up cutting the coil wire at the ecu due to interference... This will be fixed and crimped with environmental raychem splice... Basically makes a perfect connection again*** *These were cleaned in April 2018 and received a great feedback along with flow patterns well within T1 / ID's parameters. *Gauge/sensor is 1 year 2 months old *2 years old. **This is an aftermarket housing with OEM brand new stock guts..(Used a brand new B18b1 housing from Acura to make this) (-16an hoses and relay / wiring will cost extra) ***This radiator is not for the average user... It WILL require custom fabrication and alteration to the vehicle... I had a fabricator at my job create a U channel and bracing made to replace stock radiator support frame.. This requires a great deal of thought and prep to ensure the final job is not only safe but ensures the radiator's got the space to move and free float without falling... Ron Davis recommends 1/8 -1/4" 40 durometer rubber for isolation 4) *Already ported by 4piston to the B16 engine *Paint it again and it'll look great again though) This was made to fit where the stock battery goes on the Tegs *Lines not included!* **Comes with 7/8" Civic Brake Master Cylinder** Made with Earls SS Perform-o-flex hose and Earls Nickle fittings.. Sized perfectly for B16 Engines.. 13) B series block Thermo Housing -16an modded $35 14) B16 -16 modded water outlet - $35 *Both 13/15 parts are custom welded with a -16 line and will come with whatever sensor is on the part** OK - That's about it for now... any Stock / OEM car parts are currently not for sale.. *Only aftermarket parts are for sale* I believe the majority of the pricing is within reason..I will entertain any and all offers though. Again - Questions? Ask them! ******Additional Pictures continued on next post... Files may be too large to copy all at once... PM / Reply with Q's ... Thanks! ** Some items have been reduced - if "SHIPPED" is behind the price that's shipping included.... all other items will require an additional shipping expense... REMEMBER - I WILL ENTERTAIN REASONABLE BEST OFFERS! https://cimg3.ibsrv.net/gimg/honda-t...482a4ceadc.jpg https://cimg9.ibsrv.net/gimg/honda-t...8d48fd78db.jpg https://cimg0.ibsrv.net/gimg/honda-t...a500c8bec6.jpg |
Re: B series PART OUT.. Full vehicle setup - engine, electronic, chassis...
Last couple... Any specific detailed pictures needed please let me know... Thanks!!!
https://cimg2.ibsrv.net/gimg/honda-t...1260ca385d.jpg https://cimg4.ibsrv.net/gimg/honda-t...8c014159e5.jpg |
Whats your price on the whole engine? I really only need the block and head but if your not willing to part out the engine thats ok im fine with spare parts
Originally Posted by silverbullet9626
(Post 51758571)
I planned on parting the head and was going to sell the block with internals.. Just so you know it might be a week to a month before I can get to pulling the engine. Pm me for my phone number and we can hash out specifics if I think your offers fair... |
Hondata/ ecu -sold
wideband - Sold Dizzy - Sold Cdi, coil, icm bypass - Sold |
Alright... I've been selling some stuff but there's a ton left. I add new items every couple days so make sure you check back. All items are OBO.. Several items have been purchased under asking.. Just know there's only so far I'll go on items...
Also - Some items are rather large / heavy.. These will take extra care to package and may require additional shipping costs.. (IE bubble wrap / bracing in the interior of box, packing peanuts ...etc etc..) Any items purchased ... it is the buyers responsibility to dictate insurance coverage value...... Priority = $50 / UPS = $100... Any additional coverage needs to be stipulated up front so the shipping costs can be accurately requested. Any questions do not hesitate to reply to thread or PM me. I' make time throughout the day to answer so there shouldn't be more than a couple hours delay if that. Thanks, Joshua |
Just wanted to say thanks for the injectors. They were packaged well, shipped fast, as described, and the communication was excellent.
10%**** off all items for the next 24 hours.. (Ends 11/2/18 @ 6:42am central time)
***15% off all items ($299 and below) for 24 hours... (ends 11/2/18 @ 6:42am Central) ***This does not include shipping expenses*** |
Thanks for the sandwich plate! shipping was really fast! I'm going to look your list over and may grab some more stuff!
Ok, I added some new items... lowered price on a couple others..
I'll do some combo deals... purchase two items and I'll knock a flat $15 (For two items total), $40(for 3 items total) off price or 20%(4 or more items total...) Purchase -16an hoses and block / head outlets $40 off... etc. Message with any questions. details, etc! All reasonable offers are entertained and best offer will be accepted. *Depending on items purchased additional shipping charges may apply. IE 1 item included shipping but 2 other larger / heavier items did not... |
Sold a couple other items... still got some good pieces left. Make an offer... worse that'll happen is I might not accept it..
Most every item purchased has been through reasonable offers.. I'll work with you if you work with me. Any questions just ask! significant price drop on the Rywire harness.. over $500 off! I can throw in some 2ga / 4ga battery / ground wires also! - Crimped with appropriate hex dies |
Is the clutch line for integra ? |
Originally Posted by Edgar Mojica
(Post 51783021)
20 shipped ? |
(Post 51783025)
20 shipped ? |
Ok it’s in good condition and everything? |
(Post 51783027)
Cool 6145174833 |
Received the intake and tb today, fast shipment and everything was packaged well.
Originally Posted by cheetoh
(Post 51783840)
Fidanza Flywheel sale is currently pending.
The oil catch tank is great thanks!
10% off and free shipping for all items left! ! Next two day! Friday 23rd - sat 24th
Is the Momo and quick disconnect for sale ? how much? Also do you know if the splines will fit a gen2 teg?
