What modifications are needed to swap the UCA's for more + Caster?
I have a 92 Civic Si. I just got it aligned and discovered that the caster is almost at zero! I have the Skunk 2 UCA's to swap in. I know that swapping the UCA left to right and vice versa will give more + caster.
What I need to know is what needs to be done in order to keep the control arms from damaging the strut towers? Thank you. |
Re: What modifications are needed to swap the UCA's for more + Caster? (95GSRRacer)
Re: What modifications are needed to swap the UCA's for more + Caster? (.RJ)
I suppose the " https://honda-tech.com/forums/images...s/emhammer.gif " is to me? I did a search for everything but "caster". A search for caster is leading me in the right direction but havent seen the answer to my question, yet...
[Modified by 95GSRRacer, 10:59 PM 2/27/2003] |
no, he means a plastic coated dead blow 2-5lbs hammer and a ball joint separator. https://honda-tech.com/forums/images/smilies/emwink.gif
i gotta do the same, but that could be done when i get the new steering rack, and that could be doen when i get jimfab's CM, and that.... stan |
Re: What modifications are needed to swap the UCA's for more + Caster? (90crxsi)
ding ding.... if it doesnt clear, take a deadblow to that beeyotch and own your fender wells.
