Torsion Bar questions
I am building an E prepared 87 CRX Si and I am looking at my torsion bar upgrade possibilities, since I am new to torsion bars I need some help. First what are the stock size? I have found 23mm, 27mm, and 29mm upgrades available, what do these sizes correspond to in "spring weights"? ie: if I were running a 29mm torsion bar and I wanted a spring for the rear that was 50lbs heavier what would I get?
Also this may be a dumb question but what exactly does the panhard bar do? As the suspension moves does it keep the axle aligned?? TIA
-Joel
-Joel
Re: Torsion Bar questions (B17CR-X)
The stock Torsion bar is 18 or 19mm. I upgraded from 21.5 to 27mm bars on my '85 Honda Challenge CRX. I have 450 lb. rear springs, which is a pretty good match for 27mm bars. I would need to go up to 600 lb. rears, for 29mm bars.
The Panhard rod keeps the body from shifting side to side, and a bent or broken Panhard rod makes the inside of a rear tire rub the inner fender (ask me how I know this).
Re: Torsion Bar questions (kedwards)
Pdahondas88
22
04-07-2018 09:46 AM
T_Rex
36
01-23-2003 05:45 PM
