Spare parts needed at the track-add to the list
i am compiling a list of spare parts that should be taken to the track with my road race car. since i have built a track only car, im assuming im going to break parts because of how hard ill be on the car. if you broke something at the track, add it o the list, i want to know what seems to readily break. cant miss a race becuase of a breakage!
here is what i have already:
1. brake fluid
2. engine oil
3. coolant/water
4. distributor cap and rotor
5. spark plugs
6. plug wires
7. coil
8. axels
9. wheels
10. timing belt/alternator belt
11. radiator hose
12.???
1. brake fluid
2. engine oil
3. coolant/water
5. spark plugs
6. plug wires
7. coil
8. axels
9. wheels
11. radiator hose
12.???
Re: Spare parts needed at the track-add to the list (yeah LS)
What kind of car is it? Being a Honda, you might consider having a front hub on hand. They're weak and should be changed every couple of races anyhow. Brake rotors are good to have on hand.
If you go to a new track, find out where the closest auto parts stores are BEFORE you need them. This will spare you some panic when you find that the thing that broke is the one thing you don't have on hand!
Scott
Scott
What is this for? Track day? Race?
Do you really need a coil? Just install a new one and you should be good for a few years.
Uhh, if you need a timing belt, you may as well bring a whole long block. Hondas are interference motors.
12. brake pads
13. brake rotors/drums
14. fuel pump
15. fuel filter
16. diff and tranny oil
17. hub/bearings/etc
18. tie rods
19. transmission
20. diff/rear end
21. brake calipers
It really depends what you're doing. I being oil, brake stuff, plugs and a spare wheel/tire. And all the tools I need to install/fix common problems. Any other parts I borrow/buy from friends. But, I also don't tow, so don't have room for big bits and tons of spares.
1. brake fluid
2. engine oil
3. coolant/water
5. spark plugs
6. plug wires
7. coil
1. brake fluid
2. engine oil
3. coolant/water
5. spark plugs
6. plug wires
7. coil
8. axels
9. wheels
9. wheels
11. radiator hose
14. fuel pump
15. fuel filter
18. tie rods
19. transmission
20. diff/rear end
21. brake calipers
How about:
-rad cap
-tranny fluid
-hoses and clamps of various sizes
-throttle cable
-zip ties, racer tape, wire
-tire repair kit
-extra lug nuts
-rad cap
-tranny fluid
-throttle cable
-tire repair kit
-extra lug nuts
Re: Spare parts needed at the track-add to the list (Gansan)
okay okay everyones blowing up their motors this time-a-year and i just hope i dont blow up mine! and no i cant bring a spare car!
thanks glen!
thanks glen!
Trailer and tow vehicle. Never know when the car is going to be undriveable for the ride home.
I believe that my engine is next on the list to go...
Joe Yau,
Paul S.
then you Glen...
sigh... I am the last R with a running motor at TCRA
Joe Yau,
Paul S.
then you Glen...
Re: Spare parts needed at the track-add to the list (Andrew)
hey D, you saying that your motor is just not going to stand up to the abuse? then yeah i believe you. if i were you id start building a strong block -in fact have the new motor standing by. im gonna need someone to race with when i get the LS going.
what happened with joe?
To bad its in December
Location: Formerly of SF moved to DFW and now back in SF, CA, USA
Re: Spare parts needed at the track-add to the list (Chris)
Don't forget Racers tape! My friend used it to hold up his rear bumper! heheh! Miscellaneous bolts too. Another firend lost one bolt from his Slave Cylinder. He finally got one from a cool Mazda guy!
Bring spare parts for yourself too! I bring water and energy bars. And some money for the snack bars when I get sick of the energy bars!
Re: Spare parts needed at the track-add to the list (smokin rubber)
Head is overkill. If you need a new head, it's probably because something ran into something else, which means bottom end is probably damaged too.
I don't think anyone's gonna be pulling the head at the track. I only know a few nutballs willing to do that.
No one's listed JB Weld yet. This one is essential, especially if you don't have a tow vehicle and trailer! Forget about replacing the broken parts at the track, just repair them to a reasonable state to do what it needs to do (like get you home).
Warren
Warren
Re: Spare parts needed at the track-add to the list (Warren)
im glad you guys have a lot of input: however, specifically i am talking about spare parts needed so that i dont miss the final race on sunday. i will be towing the car so that doesnt matter. mainly its a disappointment to break b4 the final race. this is an integra fyi.
thanks
thanks
Ludehrt
21
03-05-2012 09:13 AM
577HondaPrelude
18
06-15-2004 03:57 PM
