Shifting rear sway bar
Hello all,
Today I installed a blox 20mm rear sway bar on my '99 Civic Si with an ASR rear brace. The brackets supplied by blox look identical to the factory ones, and are not compatible with the ASR brace as bolt spacing is different and the ASR brace also pushes the bar towards the rear by a couple inches. I used a set of universal energy suspension sway bar brackets and bushings to fix this. My issue now is that the blox rear bar has a small bend right where the bushings end up (when centered), and this makes my sway bar want to slide to one side. Here's a couple pictures showing evidence of the bend...see the gap between the bushing and bar circled in yellow? http://i45.photobucket.com/albums/f7.../EM1/sway2.jpg http://i45.photobucket.com/albums/f7.../EM1/sway1.jpg So I took it for a quick spin around the block (clockwise, all right turns) and took a look under and found unsurprisingly the bar had slid over. Sway bar in bushings after sliding over: http://i45.photobucket.com/albums/f7...e/beac1e04.jpg Passenger side after: http://i45.photobucket.com/albums/f7...e/b59791ca.jpg Drivers side after: http://i45.photobucket.com/albums/f7...e/ec3b14b9.jpg Now my best bet is probably to get an ITR bar like everyone else as I know it'll work, but I'm cheap and I've waited through several setbacks to get this bar on so I'm wondering what everyone's thoughts are on putting on some shaft collars (or a strip of rubber and a hose clamp) to keep the bar centered? I know Nissan uses shaft collars from the factory on some of their sway bars. I'd probably go through bushings pretty quick, but would there be any other side-effects? Maybe just for the last 2 autox weekends this year then change it over in winter. Co-driving an STS '95 Neon ACR has ruined driving my car for me.:P |
Re: Shifting rear sway bar
Can you shoot some pics of the end links, and LCA's?
With the gap in the brackets and holes not lining up, it seems it was a bad combo from the start. Im wondering if the endlinks are partially to blame. |
What specifically are you looking for? Both the endlinks and lower control arms are stock EM1 parts.
The holes not lining up is pretty normal, adapting ITR sway bars on EK chassis have the same issue/fix. I guess it just turns out ITR bars do not have that small bend in that location. |
The end links also allow play that let the sway bar move.
Im pretty sure the energy bushings are 22mm
Originally Posted by dirty19
(Post 45916726)
Put two split collars on the bar inside the U brackets for a temporary fix and purchase a bar that fits your bolt mounting and brackets on the ASR brace for next year. |
If your rear bushings are indeed too large for the swaybar, then you might want to go with greaseable rear bushings. I got mine at Amazon like:
http://www.amazon.com/Energy-Suspens...515460&sr=8-22 As far as the swaybar shifting sideways, some swaybars have built in collars to prevent that. My swaybar didn't, so I ended up buying a few shaft collars from McMaster Carr like you and DB2-R81 mentioned - the shaft collars are listed in the Metric Two Piece Clamp On section in the following webpage: http://www.mcmaster.com/#shaft-collars/=dt8c4q I've heard that some people get large washers welded on the swaybar to prevent the sideways movement, but I went with the clamp on shaft collars, and they're working fine. I think that you would probably need to put them outside the rear bushings as there probably isn't enough clearance between the sway bar and the ASR brace to the inside of the bushing. PS - I had the same type of issue with my sway bar shifting to one side with the thread being https://honda-tech.com/forums/showth...ight=calif_kid - Jim |
Originally Posted by DB2-R81
(Post 45916990)
First off it's an anti-sway bar, second, that what end links are designed to do.
Put two split collars on the bar inside the U brackets for a temporary fix and purchase a bar that fits your bolt mounting and brackets on the ASR brace for next year. Adjustable ones take alot of play out. Jim.. those greaseable bushings are the best. Keeps the bar from binding hence it doesnt become a third spring. |
the progress has removable O-ring on the bar to keep it from moving.
the ASR has some kind of welded stopper. chaging the D bracket won't help in anyway shaft collar Calif Kid has posted is the solution |
6 Attachment(s)
Sway bars should have welded stops as shown in picture. But when they don't, as others have said, add split shaft collars. Whiteline makes the fancy gold ones. Try McMaster Carr.
http://www.mcmaster.com/#shaft-collars/=dtf90w |
Excellent post. this kills all possible ways for it to move.
I like these solutions. |
Originally Posted by alphalanos
(Post 45916766)
http://www.energysuspension.com/prod...-Bushings.html I'm using the 20mm bushings - part # 9.5124
(Post 45916990)
The only real way the sway becomes a third spring and causes more stiffness than is wanted is when it binds. But the energy suspension bushings take care of it with lubrication.
Check out Jim's link above we covered on this subject a while back. It helped cure my issues. |
