R compound or not to R compound
Ok, im currently racing sts. For next season im getting separate tires and wheels. Ive been considering different tires and my question is, do R compound tires take u out of sts, and tell me which on my list are r and not R compound
Yokohama parada spec 2
Kumho Victoracers
Kumho v700 ecsta's
Falken Azenis sports
any others i should consider, i know the hoosiers are R compound, someone help me
Kumho Victoracers
Kumho v700 ecsta's
Global Moderator
Re: R compound or not to R compound (Sleepin 95 Tegra)
STS does not allow R compound tires.
On your list, only the Kumho Victoracers are R compound tires.
Get some 15x7 Kosei K1s with 205/50/15 Azenis tires for a *relatively* cheap setup.
R compounds may not last as long, cost more, force you to swap tires (if you car is also your daily driver) but it's so much fun to drive on R tires. I was told, once you switch you never go back, and it's so true.
I don't know about the Yokos (I wouild guess street), but the Kumhos you listed are R tires and the Falkens are a street tire.
Re: R compound or not to R compound (Reid)
Ok Does everyone running integra's run 205's or does anyone run 225 in front?? looking for help here. if people could post their tire sizes they use and what tires rims etc, There is just soo much info out here its hard to grasp, and anyone know step by step install of a tach on an integra
Most runs 205s. Some have 225s up front. My advice - run fornt and back the same size untik YOU know why you might want to do otherwise.
New User
Track: Yokohama A032R 205/50-15 on stock rims front and rear
Street: Bridgestone RE010 195/55-15 on stock rims front and rear
Winter: Michelin Arctic Alpin 195/55-15 on stock rims front and rear
1991 NSX
Track: Yokohama A032R 205/50-15 on stock rims front and 225/50-16 on stock rims rear
Street: Yokohama A022H 215/45-16 on stock '95 rims front and 245/40-17 on stock '95 rims rear
Winter:
New User
Re: R compound or not to R compound (nsxtcjr)
My set-up: 2001 Integra Type R, 15" SSR Competiton wheels with R-Compound Kumho Ecsta V700 tires all year long. If snow starts to fall, I rush out into the driveway and swap my stock wheels with Michelin Pilot Alpin tires, until the snow is plowed, then I swap back again. I love R compound!
