Qa1 springs?
Qa1 springs?
i want to up the spring rates on my car currently running koni yellows with 400lbs front and 450lbs rear eibach springs and gc coilovers. i want to up them to 500lbs front 550 rear..i work at a race shop specializing in drag racing and we stock qa1 springs and afco and i can get them cheap...i was wondering if there r any differnce in diffenrt manufacture springs or wat not i no there r progressive spring that r wound differnt....i would like some input on wether to get them or not
Ridin Dirty in Cali
Re: Qa1 springs?
Has the educational process failed here?
Come on man.. no need to speak all ghetto.
As long as your koni's are the race valved they should be able handle those rates easilly.
Heck I have heard of people using the regular OTS konis with a 500lb springs before too.
I dont know how long they last but its been done.
If thats what you can afford then get them.
You also should check our for sale thread you might be able to pick up a set of eibachs cheap too.
Suspetise...
1 Post
Re: Qa1 springs?
For your purposes, that brand will be fine. Typically a "better" brand, or more reputable company will have better quality assurance measures in place, so that you are getting just what you're ordering. A less-reputable brand might sell a spring as a 500lb unit, but it is actually 432lb or whatever.
Re: Qa1 springs?
and i wanted to no if anyone had up to date knowledge or experience i dont want to put crap parts on my car but if a spring is a spring then it is wat it is but i wanted to no if any if there r variance in how springs r made or what have u....
Suspetise...
1 Post
Re: Qa1 springs?
If you want a guarantee of known quality, you'll have to go with a known spring like Eibach, Hypercoil, etc. If you guys have any customers who have used them they could probably give you better feedback than we can. A quick browse through their site shows they have a limited selection, and definitely aren't roadrace-oriented, but that doesn't mean they won't work.
Edit: They are also pretty dang cheap for the size/weight. I'm not sure what to think of that.
davidluko
Suspension & Brakes
12
07-08-2011 09:53 AM
