Official Road Race ELECTRICAL THREAD - Info Questions and Builds Only.
#51
Re: Official Road Race ELECTRICAL THREAD - Info Questions and Builds Only.
Its called Kapton tape. It has very good heat properties. It is kind of like the electrical tape of the MIl-spec world.
I used to do Yellow heat shrink and a sharp tip sharpie for my labels. I found inexpensive label makers that will print on heatshink. The heatshirnk is a bit expensive. $25-30 for a 5ft cartridge. But the added "Professionalism" is worth it. Dymo makes the one I have. PM if anyone is interested in custom labels or more info.
EB Turbo
EB Turbo
#52
If I balled up my car, that would be the number 1 thing I would do differently from how it is now, among loads of other things.
If you had an intermittent short (one would hope not, however possible) in a race, you're not going to pull over and replace the fuse and head back out. If you had breakers accessible under your switches, or something to that effect, just push the breaker back in after a short and see if it kicks back out, maybe you get lucky, and get through the rest of the race before it blows again. Just an example.
This really could be a cool thread!
#53
Also,
I was doing cross references with Bosch VS BMW / MB Parts today. (nerd score)
I can get you guys these 0 280 130 039 Temp sensors, and the plug and pins associated with using them for 40 bucks each with the plug.
http://www.bosch-motorsport.com/cont.../html/2895.htm
Last one at the bottom.
Can also get the air temp sensors for cheap too, have to double check the price on those.
Also have voltage sheets for these sensors.
sander
sander
#54
PM Garage
Hey Casey would you mind do a simple CAD diagram or one you have worked on so I could post for everyone on OP with all the goodies either post here or email it to me at
civichb20@hotmail.com
Thanks,
Charles
Here the shirt you wanted LOL
Thanks,
Charles
#55
Thanks,
Charles
Thanks,
Charles
LOL
Let me see what I can dig up
#56
Maybe a difference of opinion here but I would avoid those binder connectors. I would use deutsch DTM or DT series of connectors. they are the most easily serviceable economical connectors on the market. I can almost guarantee somebody at the racetrack would have pins, locks, and spare shells should you ever need to make a repair.
The heat rating is not very high on that cable either.
So what would you suggest as a connector to trminate small cales such as used on Active Sensors linear potentiometers: http://www.activesensors.com/pdf/lin...er/cls1300.pdf
Cable outer diameter is 3.2 mm or .125" with 24 gauge wire, so very small.
Also cable is Raychem type 55 with FDR sleeving. Where can you get small quantities of that cable? I tried to source it but had no luck.
And I know SAE rated cable is typically rated at 125C. But do you think 105C is really an issue? Northwire cable has been working fine so far.
#57
Source for Deutsch connectors, terminal blocks, circuit breakers and other wiring stuff.
http://www.pcsconnectors.com/
#58
http://deutschconnector.com/
These guys are awesome, also located on my coast, so shipping is generally very fast.
#59
Ridin Dirty in Cali
Thanks,
Charles
Thanks,
Charles
Charles you really like shirtique dont you.
I wouldnt wear that. Not in public anyway.
#60
PM Garage
Agreed that Binder connectors are not the best even though they are used on all the sensors and harnesses supplied by AIM, but they are very small and will accomodate very small diameter cable.
A DTM series connecter would work just fine.
Small quantities of any of the good stuff is hard to find, but if you know what you're looking for places like EFI would sell you small quantities.
Well they will sell it to me. They actually use a Raychem type 44, I prefer the 55 but there isn;t a huge difference.
If you need some stuff Claude I can get it for you just shoot me an e-mail.
For most applications I would say 105c is fine, but for certain engine bay applications it's eventually going to break down and degrade overtime and probably short internally.
#64
Good wiring loom prep thread with many pics here:
http://www.apexspeedtech.com/phpbb/v...st=0&sk=t&sd=a
#65
A couple of very nice professional wiring loom fabrication diagrams with some Deutsch connectors, etc.(not race cars but worthwhile for drawing styles):
http://www.rdstec.com/Shared/Files/cb217-2-003.pdf
http://www.rdstec.com/Shared/Files/ac380-1-010.pdf
http://www.rdstec.com/Shared/Files/cb372-1-011.pdf
http://www.rdstec.com/shared/files/ac100-schematic.pdf
http://www.rdstec.com/Shared/Files/p...-schematic.pdf
Radical SR3 Wiring loom: http://www.tillingmotorsport.com/sit.../SR3wiring.pdf
http://www.tillingmotorsport.com/sit...ingdiagram.pdf
#66
Nice loom overall but there are a few practices I disagree with especially the service loop bullshit, and using "filler" wires. It's a wiring harness not a god damned art show, and if you know what you're doing in your design work you don't need them. not to mention the weight increase
#67
#68
I'm wiring up wheel speed sensors for the Race Logic in my Street Mod Solo II car. I'm using OEM Honda sensors, but they'll be wired directly into the Race Logic ECU. What I'm after is 2 conductor shielded wire with that grey outer sheath shown above. Anyone have a decent source?
#69
Slightly more affordable alternative to DR-25:
http://www.racewireandcable.com/prod...bing/rl150.php
#70
You will use filler wires to fill out certain size heatshrink. Filler wires are used when twisting doesn't come out as nice as it should be, high and low spots. Proper twisting techniques will not make high and low spots. Kaptan Tape is also used to cover high/low spots. filler wires only add to the overall harness weight and overall aesthetics. A proper made harness will never need filler wires. With function comes form.
Hey EKasey, you know neel at Apex, right? ; )
EB Turbo
#71
In my opinion if a harness is properly designed and constructed you will not need service loops. crimp correctly and appropriately and properly strain relief your harness. If there isn't a proper strain relief available ( sealed hard rubber boot), then provide one by attaching it with a zip tie to something that is rigid.
I'm personally not the biggest fan of Dr-25 there are some better options out there that offer superior abrasion resistance with minimal loss in heat resistance( about 10 deg C if I recall). I will try and dig up the data sheet. Plus I don't like the fact that it doesn't shrink that well.
Jake PM me I can get small quantities of wire. I'm sure you can find it online for a reasonable price though.
Known Neel for a few years.
#72
Is there a faster way to do the twisted wiring? I cant imagine everyone twisting their harness by hand that would take forever.
#73
I'm making a "swap" harness this evening for a 240 sx, with a 07 350 z engine in it, pretty excited to get started, ill snap some pics over the next few days.
s
s
#74
#75
