Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Road Racing / Autocross & Time Attack (https://honda-tech.com/forums/road-racing-autocross-time-attack-19/)
-   -   normal operating temperature of d16z6 (https://honda-tech.com/forums/road-racing-autocross-time-attack-19/normal-operating-temperature-d16z6-1725865/)
OpTiX619 Aug 18, 2006 11:45 AM
searched but did not find a difinitive answer. what is the highest temp that the car should reach before I start getting worried? 220F?
Thanks,
dan
OpTiX619 Aug 18, 2006 07:23 PM
Re: normal operating temperature of d16z6 (OpTiX619)
ttt
civicrr Aug 21, 2006 11:00 PM
IIRC, the thermo opens fully @ 195 F. 220 seems pretty hot to me. I want to say my car, with Integra radiator, never sees 200 even when racing nose to tail. This is with a HC4 build on the motor running a oil cooler.
With the old Fluidyne Civic radiator (1/2 width), even with a block off plate on the a/c side, it ran close to 220.
roppetty Aug 22, 2006 04:47 AM
my fans turn on at 210ish i believe, might be around 220. i see 220 when i'm driving hard and stop, but it doesnt stay up there for long. driving hard it's around 200ish, maybe a little less. if they're supposed to come on 195, i have a problem then, lol. need to check the service manual i guess
edit - just checked my haynes, it does say the thermostat opens at 195, so 220 may be too hot
Canopa Jun 14, 2023 12:13 AM
Hi, my car running normal, but my radiator fan turn on at around 230 f what should I do?
Kaan Jun 14, 2023 07:41 AM
you need to check to make sure your gauges are correct, maybe replace the fan temperature sensor, and if you have hondata, check the settings to make sure the temperature is set where you want it.
dirty19 Jul 30, 2023 01:01 PM
When I had my D16Z6 I used a Mishimoto Integra radiator and dual fans on a dedicated switch.
Even on the hottest days on track would it ever get past 210.
Canopa Aug 2, 2023 04:07 AM
Thanks.. I see now.. I just got the bluetooth datalogger installed, and it's showing that my temperature sensor reading -27' it's been like that all these years omg.. engine check not showing.. just replaced the temp sensor and everything works flawlessly
Nice.. That's a great idea to use a dedicated switch!
