My Newest RR project
Been a while. Thought I'd drop in and say hello H-T
All of my extra time over the last two years have gone into this. When I am not at a Grand Am race, I am in my shop fingering this.
Drivetrain: K20a2; fresh before install
* Type R cams
* RBC intake manifold, HPC coated
* DC swap header, HPC coated
* Hondata Kpro
* 2.5 in race exhaust, dumps at the rear control arm
* Karcepts A/C & P/S delete
* Karcepts Intake w/ velocity stack
* K-tuned black -6an fuel line kit w/ Aeromotive FPR
* Skunk2 composite fuel rail
* Complete Motorsports engine harness, recovered in Techflex PET
* EKK2 Hasport mounts, welded/gusseted to chassis for more rigidity,
* DC sub frame to move the motor lower and back in the chassis
* Setrab oil cooler, black element
* Samco black silicone radiator hoses
*Type R tranny 4.764 final
* Quaife LSD
* New OEM axles
Chassis:
*10pt cage, legal for SCCA, NASA, MPRA, FIA and whatever else you want to race
* Cage is gusseted at A pillars, clearances are so close we were able to simply weld it at the base of the main hoop and top of the main hoop. Rear strut towers are boxed and braced
* Entire chassis harness pulled, lightened wrapped in Techflex, only necessities kept, new fuse block and relays
* Lots of engineering in the cage and chassis build, such as keep weight as centered as possible, we can discuss on purchase or a trade deal is made
* MOMO Safari helmet bolstered race seat.
* MOMO Mod 08 suede steering wheel with MOMO quick release
* OMP 5pt Hans compatible harness
* Dash is completely gutted, SI cluster, fuel switch, ignition switch, power switch, are all that are left
* All vents, radio and HVAC holes are plugged with honey comb carbon Kevlar custom pieces
* Shift box was elevated and moved closer to driver for ease/speed of shifting
Wheels, brakes:
* 15x9 4-100 35mm TRM
* 15mm front spacer; 10mm rear spacer; ARP extended studs
*Wilwood 12in, 4 piston BBK,
* EM SI rear disc brakes
* Goodridge stainless steel lines all around
* EM SI Brake master cylinder and booster
* ATE super blue DOT 4 fluid
Suspension:
*Progress coilovers, custom spring rates
*Hardrace front upper control arm, spherical bearing
*Hardrace front lower control arms, spherical bearing
*Hardrace rear upper control arm, spherical bearing
*Hardrace rear toe arms, spherical bearing
*PCI spherical bearing rear trailing arm bushings,
*Skunk2 rear lower control arms, custom spherical bearings
*Karcepts front swap hubs, allows use of 36mm axles, no more expensive swap axles
More pics and info on it here:
http://www.facebook.com/#!/innovativegarage
* Type R cams
* Hondata Kpro
* Quaife LSD
* New OEM axles
Chassis:
Wheels, brakes:
Suspension:
Re: My Newest RR project
Thanks Fellas. Originally, I started building it for World Challenge. They were struggling a couple years ago and made a TC class for older cars E36, EK, RSX and such. Rules changed since I've finished, so its pretty close to NASA Challenge H1 rules. Recently I have had thought of racing in this series: http://www.facebook.com/MPTCC?fref=ts
Its a modified Chargespeed replica.
Thanks everyone. Its been a LONG fun build. Still more to come. Details, aero and livery still to be worked out.
Car looks great. Could you give some more info on the wiring? I'm going to be re-wiring my track car soon and am a little hesitant about electrical work. What of the stock wiring did you retain, what fuses/relays did you use, etc.
sweet build.
how was fitting those wheels with the fenders and bbk? what size tire? those are the miata spec c3m wheels, correct? i ask because i'd like to run a similar setup on an eg hatch. right now i have the 15x8 +20 trm wheels with 225-45-15 rs3's.
thanks.
-drew
thanks.
-drew
We're running a 949 Racing 15x9 +35 offset wheel on our EK coupe, and it wasn't really that bad fitting them. We're running 225-45-15 Nitto NT01s.
We had to run 15mm spacers up front and had to role the fenders a little bit. We did have some spots where the wheel was hitting the inside frame rail, but that was easily fixed with the spacers once we put them on.
The wheels were not bad. They are the TRM 15x9 with a 15mm spacer in the front and 10mm spacer in the rear. Fenders were rolled and that's about it. Tires are a 225/45-15 Continental Grand Am slick. They actually measure about 9.5 inches of rubber touching the ground mounted. So they are quite a bit wider than your normal 225/45-15.
Also for got to mention, the harness was recovered in that Techflex sheith. Old fuse box and relays chucked in favor of the units pictured.
nice car bro .im working on turning this ek four door i have into a weekend warrior.. it all stock right now but i just bought gsr spindles, skunk2 pro s coilovers and rear control to get my car ready for handling, i also have intention of putting a k series motor...nice setup
