Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Road Racing / Autocross & Time Attack (https://honda-tech.com/forums/road-racing-autocross-time-attack-19/)
-   -   More LSD talk (https://honda-tech.com/forums/road-racing-autocross-time-attack-19/more-lsd-talk-1421951/)
bosco500 Nov 2, 2005 11:08 AM
More LSD talk
The last race at Rockingham I wasn't too pleased with how my diff was performing. I decided to go ahead and pull the tranny for rebuild, and am seriously considering just welding the thing up to see if I like it or not. I've seen old ford diff's welded, but just want to make sure I hit it in the right spot. What is the best way to weld it up? Its a stock R diff.
EdoMoto Nov 2, 2005 11:17 AM
Re: More LSD talk (bosco500)
Get a spool. So in case u dont like it you can put in the R diff back in.
rotten Nov 2, 2005 12:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bosco500 &raquo;</TD></TR><TR><TD CLASS="quote">The last race at Rockingham I wasn't too pleased with how my diff was performing. I decided to go ahead and pull the tranny for rebuild, and am seriously considering just welding the thing up to see if I like it or not. I've seen old ford diff's welded, but just want to make sure I hit it in the right spot. What is the best way to weld it up? Its a stock R diff.</TD></TR></TABLE>
First thing you need to do is get an open differential that fits your ring gear. You don't want to weld the type r diff.
http://www.fatboyraceworks.com/album...0174.thumb.jpg
At a minimum you want to weld the spider gears together like in the picture. You can also weld the gears to the housing.
Try not to heat the unit up too much, as it can warp.
bosco500 Nov 2, 2005 12:36 PM
Re: More LSD talk (rotten)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotten &raquo;</TD></TR><TR><TD CLASS="quote">
Try not to heat the unit up too much, as it can warp.</TD></TR></TABLE>
Thanks for the info and the pic.
.RJ Nov 2, 2005 12:38 PM
wrong link on the pic - http://www.fatboyraceworks.com...4.jpg
Mr.Noodles Nov 2, 2005 03:51 PM
Re: More LSD talk (.RJ)
If you're going to weld it up, make sure you insert the axles into the diff prior to welding and then weld the spider gears. It won't transfer enough heat to the axles to screw them up and ensures the welded diff's splines will line up with the axles when installed. https://honda-tech.com/forums/images/smilies/emthup.gif
Honda318dx Nov 3, 2005 03:48 AM
Re: More LSD talk (Mr.Noodles)
spools are cheap and cut down on rotational mass..
Type_RS_59 Nov 3, 2005 09:18 AM
I'll trade ya for a stock '98 Integra RS open diff. It's already out of the car and ready to go.
.RJ Nov 3, 2005 12:49 PM
Re: More LSD talk (Type_RS_59)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_RS_59 &raquo;</TD></TR><TR><TD CLASS="quote">
I'll trade ya for a stock '98 Integra RS open diff. It's already out of the car and ready to go.</TD></TR></TABLE>
That wont fit - ring gear patterns are different, he'll need a GSR diff.
bosco500 Nov 3, 2005 02:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">That wont fit - ring gear patterns are different, he'll need a GSR diff.</TD></TR></TABLE>
What he said https://honda-tech.com/forums/images/smilies/emthup.gif
