Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Montana CHUMP car build #1
Old 04-21-2012, 07:09 AM
  #51
eastbay92cx's Avatar
Default Re: Montana CHUMP car build #1
Chump car? Lol more like super awesome race car
Old 04-21-2012, 07:45 PM
  #52
vectorsolid's Avatar
wait'll you see the dash!
...lol...
Old 04-22-2012, 12:30 AM
  #53
Whew, been banging out the work.
Randon got new bearings in the front, and pressed in the longer ARP wheel studs. Waiting on new rotors and pads. these rotors are shot, and out of spec.
Helmet kits got here for the radios.
Wheels and tires got here. Bumper covers are here.
Made a pimping little dash for the switches and the master kill switch. To make it easier to work on stuff, It can be tilted up and out. Or down and back over the shifter, or simply removed. Once it's slid into place and locked, it's hella tight and strong!
Old 04-22-2012, 12:42 AM
  #54
Here's the scoop. We needed a place for the switch panel and the master kill switch. CHUMP rules really curtail doing the pimpy and fun stuff. Unless it's for safety. SOooo, I made this real nice, stiff, safe switch mount for the master kill switch. I even managed to incorporate some dzus fasteners on it. ...lol... That white top will get replace with carbon fiber... or we might just paint the whole assembly flat black. haven't decided. Just wanted to have a unique switch panel.
To make it easy to get to the wires, it pivots up and locks to the cage when parallel with the windshield. Pivots back over the shifter, or can be removed entirely in under 6 seconds by one person.
Tilted up:
Or tilted back over the shifter. At this point, one pin and it's out in under 3 seconds.
Old 04-22-2012, 05:14 AM
  #55
essex's Avatar
can you please gut that steering column support and hang it with with rodends it will look so much nicer and match the rest of the nice tube work.
Old 04-22-2012, 10:59 AM
  #56
100% agree.its on the list. Were seriously under the gun for time. So, for now, we have to run the column in the stock configuration. It works. But for sure its gonna get redone. :-)
Old 04-30-2012, 03:46 PM
  #57
Went to work on the suspension. ALL of the suspension bolt heads were sheared off, which explains the old shocks on the car. We had to actually replace all the LCA's and one front shock fork because of it. That killed about a day.
Here are some progress pics.
Had this old REX suspension, was hoping "something" would interchange.. Nope. oh well, was worth a shot.
You know how you see certain racing on TV and theres always somebody dragging a bumper cover? This was our idea to help minimize that. Those aren't rivets along the top edge, those are welds.
Old 04-30-2012, 03:54 PM
  #58
6 point Schroth belts, to work with the Hans device.
IN and mounted... FINALLY. What a pain that sub strap was. But better for the old "twig and berries in an emergency situation.
Drum brakes suck, but we're gonna make the best of it. I don't know what people normally do, we decided to just write on the shoe to check wear, later. Had to convert back to drum when we ruined all the control arms. It's all I had for spares. Gotta do what you gotta do in a pinch.
Old 04-30-2012, 03:56 PM
  #59
miamirice's Avatar
This thing is far too nice!!! I love the switch set up, our chumper has the gauge cluster held by doubled zip ties.
Old 04-30-2012, 04:00 PM
  #60
Engine was a FILTHY mess. YECH. We needed to pull the transmission and replace it and the clutch.. trans had some grinds and the clutch was used up.
Power washing the filth off in the driveway.
Here's where you don't want to be, 3 days before you have a race.
New transmission in, Thanks to the Speedfactory for the quick help on the transmission and parts. :thumbup"
Old 04-30-2012, 04:04 PM
  #61
Took the ebay 4-2-1 header, cut the end off and upp'd it to 2.25 piping from the 2". Necessary on a stock D engine? Probably not. Fun project though. Had to do a new exhaust anyway. the other one was a disaster. been welded to and parts changed out maybe 4-5 times. Was a good candidate for a "failed fabrication" thread.
Flex pipe welded on the new flange.
Old 04-30-2012, 04:07 PM
  #62
Ebay coils are on, and new set of kyb Gr2 shocks. Shocks suck, but they're cheap and fill the rules, so that's how that goes.
Rear suspension is WAY to stiff with the eBay coil springs on it. Might cut down the old fronts and stick them on the back.
Anybody have a rough idea how heavy a spring ends up on a road race car, front and back? Car probably gonna weigh 2200 or so with driver. Any help appreciated.
Old 04-30-2012, 04:08 PM
  #63
my 8 second drag car has the same setup with zip ties for the cluster... ...lol...
This one, I welded some little supports on the dash bar for the cluster.
Lot's to still do.
Needs:
brakes bled and set.
Wiring wrapped up.
Doors mounted.
Radio installed.
Master Kill switch
Lexan windows made.
trunk made and mounted.
CV's put in.
window net put in.
windshield.
exhaust system finished.
AAHHhhhhg... running out of time.
Old 05-01-2012, 07:22 AM
  #64
mattEG's Avatar
You've honestly got a winning car if you get it together in time. Very well done. What's the total spend at?
Old 05-01-2012, 08:43 AM
  #65
Billy Elliot's Avatar
We ordered up custom Porterfield R4-E (e for endurance) shoes on the rear for our car. We ran two 24 hours races on the pads front and rear and could go for another race or two easily.
Old 05-01-2012, 12:04 PM
  #66
If I'm honest, probably 5k. Tubing, seat, wheels, tires, shocks, windshield, lexan, etc. All add up VERY quickly.
Seems like most guys that talk about Chump stuff in an honest fashion, anywhere from $4-$6k.
But once it's done, the real value starts to shine through. This first weekend, CRAZY expensive, next weekend after that, other than fuel, tires, entry fees, is practically free. In the loosest sense of the word. ...lol...
Old 05-01-2012, 12:33 PM
  #67
You can build cars for super cheap depending on deals you can get up. We spent around $511 per driver (5 guys total) for the car which was EVERYTHING. Parts, registration, licences. Then we just split up the gas we paid at the track. Car we purchased for $1 even though we actually got it for free.
But we re-used some stuff we had (my Sparco PRO-ADV seat and harness and extinguisher which is $1100 right there) we used a BMW 2000 cage in our protege we got for free as well. All our wheels were either ones borrowed from my rally car at the time or spares from the car as well. But even then you very well could get a guy on your team who owns a race car and you can re-use all your fire extinguisher/seats/belts.
Cost Breakdown of our Protege:
500 Car Registration
500 Driver's Registration
250 Racing Licences
81.62 Radiator
43.41 Radiator Hoses/Clamp/Cap
205.6 Struts
290 Brake Pads F/R
15 Brake Fluid
43.07 Brake Rotors (Front)
30 Transmission Fluid
24.31 Spark Plugs/Caliper Repair Kit/Hose
334.56 Tires
167.28 Tires
63 Paint
110.79 Tubing
Old 05-01-2012, 12:38 PM
  #68
eight equals equals equals D
Tim2179's Avatar
That's about our PER RACE budget (after factoring build costs, fuel, race entry and travel) when we're blowing motors each race. This upcoming race will be our first with the same powerplant from a previous race. Should be interesting to see how much the budget differs.
Get used to it. This is how many competitors spend their afternoon and evening after the 1st day.
Old 05-01-2012, 01:26 PM
  #69
...lovely...
Old 05-01-2012, 01:30 PM
  #70
Tim2179's Avatar
...lovely...
If you have the room, bring spares - of anything. It is not uncommon for teams to bring parts cars to the race.
Old 05-01-2012, 01:31 PM
  #71
Yep, bringing an entire running car. Sadly, it's not a vtec engine, but it is an engine we could use in a pinch. All the control arms and main relays and all kinds of bits will interchange. I agree, much easier to bring a parts car.
Old 05-01-2012, 01:40 PM
  #72
90blackcrx's Avatar
Making caskets as well ?
Old 05-01-2012, 01:48 PM
  #73
Ha.
I got that to make a go-kart out of it.
Funeral home got it as a sample of a low- end "el-cheapo" casket. The guy gave it to me. I mean this thing is flimsy and cheap, has dents in it, weighs about 50 pounds is all. BUT, make a sweet go-kart.
Old 05-07-2012, 07:48 AM
  #74
Tim2179's Avatar
In for race report.
Did you guys stay on track for the whole time or spend countless hours wrenching in the pits? Hopefully the former.
Old 05-07-2012, 12:17 PM
  #75
race report from Spokane coming in the next day or so if enough of you are interested.
It will be a good read.
Quick Reply: Montana CHUMP car build #1
