Rim to wheel clearance
HRD PKR
i'm wanting to pick up a set of 15" rims but i'm not sure if my brake setup will clear
Wheel Specs are 15x7, +28 offset VOLK CE28's "8 spoke"
Brake specs are S2000 calipers on rsx 11.8 inch rotors.
My question is will these rims clear my calipers/rotors??
Or will i need spacers?
Re: Rim to wheel clearance
You probably already know this but RSX-S calipers and S2k calipers are the same, so if you can find someone with an RSX-S with that wheel spec then you will know for sure. Very few 15" wheels will clear Type S brakes though so I don't think your chances are great .
15" CE spoke designs are totally different from larger CE spoke designs so thats going to make it harder to compare. +28 though should clear even if the spokes are flat from my opinion. But who knows...
HRD PKR
Madeinoc- do you think if i ran a 5mm spacer it would possibly clear? i know the s2k calipers are not really bulky neither and i've heard people running spoon calipers under ce28's, then again spoon rotors are still 11.1?
volkdlr
10-27-2004 01:13 AM
