HF Swaybars
HF Swaybars
I have a 1988 CRX HF, and when I bought the car, it had a lot of Si upgrades. I measured the FSB, it came to 17.6 mm. So I assumed it is the Si FSB, so I went out to a junkyard and found a CRX HF. I stole its FSB, got home, cleaned it, measured it...17.6 mm again. My calipers are pretty good, so I dont think its an inaccurate reading. Someone said the HF bar can be identified by a label on it...what would that be? The junkyard one says "G" painted in white on it in the center. Other than that the bars look at feel identical.
Re: HF Swaybars (GI8U2racing)
The HF bar is tubular, the SI and DX are not. If you look at the end where the links connect to the lower control arm, the HF will look like a tube that has been flattened. The DX and SI are solid at the end.
drumminforev
11-03-2006 05:31 AM
NightHawkC5
02-22-2003 07:05 AM
