H2 built up, 2009 H2 Nat champ car
Here is a preview of the future 2009 national champ h2 car
Many thanks for all the support from AEM,Hasport,Tein and Kiwi from Specialprojects!
Cage build by AWR
benny
Cage build by AWR
benny
Re: H2 built up, 2009 H2 Nat champ car
Very nice. Good luck this year. I know you have 5 weeks to finish it as of today the car is still a shell.
Edo
Edo
Edo I don't need more stress !!!!!!
The car is at the body shop, hopefully getting back this weekend, so get ready for some wrenching !!!!
BTW if any good wrencher around pasadena/glendale are very welcome to come and help. plenty of beer and pizza.
benny
benny
I'm looking for rear molded lexan window.
email me if you have some, so one has them in stock until late march.
benny
info@froggertv.com
benny
info@froggertv.com
Huh, interesting title you posted. I was expecting to see this when I clicked on your thread-
Which engine are you using B16 or B18...judging from that cage, you'll probably be closer to 2400lbs. (B18c1 min weight) than 2250lbs. (B16 min weight).
nice build
nice build
B16 and because of the gussets I get a 30lbs penality, so 2280lbs, so should be able to make it. the car was completetly sand basted.
benny
benny
used to connect roll cage tubing to chassis of car. I.E. A pillar bar may have material welded to
both itself and the A pillar of the car.
f) If modification number 4.9.5 above is utilized, an additional thirty (30) pound weight penalty will
apply.
Benny
e) Tubes may be welded at any contact point, or even be “seam welded.” Additional material may be
apply.
Benny
apply.
Benny
correct mike, that is how i read it. The "seam welded" refers to the subject of the sentence which is Tubes.
I didn't do great in english but that is how i think it is worded.
here definition of seam weld: ...Resistance Seam Welding is a resistance welding process that produces a weld at the faying surfaces of overlapped parts along a length of a joint. ...
benny
benny
The section it is under is labeled "4.9 Roll cage", the sentence (seam welding) is in is a verb (action word) and the noun is tube, not only that but seam welding is in " " which usually denotes that the term is not being used in it's tradition context or definition
