Gringo's new "sane" race/track car!
#130
Re: Gringo's new "sane" race/track car!
#131
I tested out some GSC N1 camshafts:
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/gsc-n1-cams-tested-i-h-e-gsr-3152541/
#132
Numbers look really good! Stock bottom end, unported head.
Aren't those pretty mild cams? Similar to CTR/ITR?
Did you try messing with different intakes? Wondering if a longer 3" tube w/ v-stack would bump up your numbers
#134
If the cam spec sheet is right then yes the max lift on these cams is STL legal
I did not mess with intake size, i should have and i think i might later on. i am pretty sure it will pick up a little bit of power with a velocity stack on it.
#136
Looking forward to seeing your car this weekend. We have over 230 race entries this weekend.
The entry list looks pretty good, check it out.
https://www.motorsportreg.com/index....5#.UcMm55zQvAg
#137
#139
I am not racing, but i will be there flagging lol.
Nothing on that wing you have is good huh??
#146
very nice build!
Are transmission upgrades such as a final drive and more aggressive LSD permitted?
I'm sorry if I missed whether or not the car already has these mods done.
#147
Yes from what i have been told they are allowed. And something that i do need to upgrade too! Needs an LSD and maybe a 4.7 FD..
Thanks!
Thanks!
#149
So i went back to the Ridge Motorsports today with the car. It was a very successful day of working with the car.
I did some font and rear Camber adjustments yesterday before i went out today. i also put the toe back to 1/16th out up front.
I also did a bunch of tire pressure measurements and tire temperatures. To my surprise it looks like i need more camber front and rear...
Inside front tire temps: 135
Middle Front tire temp: 142
Outside Front tire temp: 145
Inside rear tire temps: 115
Middle rear tire temp: 121
Outside rear tire temp: 125
It was also a hot day, i started the rear tire pressure at 28psi and it was 34psi after. Fronts i started out at 27 and they made it up to 38psi on one session.
That being said my previous best time on this track was a 2:05.3...
Here are 2 of my sessions:
Went from a 2:05.3 to a 2:01.95 .
I am still on some old warn out 205/50/15 RA1's but they seem to be doing ok right now!
#150
Does anybody have any recommendations on Wing's? Mugen, APR, Mugen Replica,. ITR?
I kinda feel like for the money might as well get an ITR wing
