Eibach Multi Pro Shock review
This past Friday I made it out to Willow Springs Raceway in Rosamond, CA for a Test n Tune day to shake some things down on my 95 civic coupe. One of the parts of my car that I was testing for the first time since I recently bought them were the Eibach MultiPro R2 shocks. A 2 way adjustable coil over with remote reservoirs. I chose them because I could get in the to higher class 2 way shock market and do it at a great price. Made in the USA and great service was the kicker.
I wanted to share my thoughts, some pictures and answer any questions someone may have who is considering these. I have gone through quite a few sets of shocks on my race car, from custom Koni yellows,Progress Series 1, Tein Flex, and Tein Monoflex. I have driven other FWD cars with Moton triples, and Koni doubles so gathering a feel of these new shocks was fairly easy for me. The installation was quick and easy with the included top hats. I put the ERS springs on along with the helper springs and blasted the top hats on. Once I found a place to mount the reservoirs in front the next step was over, the rear reservoirs are beautifully attached to the shock. When I put the new shocks in I added an Eibach adjustable rear sway bar to compliment my setup. A corner balance and alignment session wrapped the installation up.
Once I got the car on track it drove well out of the box with all settings full soft. It was stable and they felt great as I get my pace up. This is a high speed track with an average speed of 100 mph in my car, long sweeping turns,elevation change and a lot of bumps from years of sitting in the desert sun. I was out for about a 20 min session and came in. I made some adjustments and went out for the next session. I was pleased what just 2 clicks on the compression did on one of my adjustments, the car noticeably reacted to my change and I was pretty happy. Hitting personal best lap times and consistent laps being logged I was pleased to be able to quickly adjust the balance, and get the car extremely stable. They control the stiff springs very well over bumps. I am happy with my purchase, since these R2s are very affordable, and can compare to any two way shock on the market with quality, ease of use and extremely reactive adjustments. The more time I have with them the better the car will get, since that was just one test day with 4 20-30 minute sessions. I look forward to the next day on track! Thanks Eibach!
JW
JW
Re: Eibach Multi Pro Shock review
OE ITR bar: 22 mm (0.87 in) solid.
OE measured bar rate: 51 N/mm (292 lbs/in)
OE bar weight: 3.78 kg (8.4 lbs)
Eibach bar: 25 mm (1 in) tubular, adjustable. Part# 4086.312
Eibach measured bar rate:
Position 1 = 73 N/mm (418 lbs/in) +43%
Position 2 = 94 N/mm (533 lbs/in) +84%
Position 3 = 111 N/mm (630 lbs/in) +118%
Eibach bar weight: 3.15 kg (7.0 lbs)
With my worn and corded tires and a slower gear ratio, I was still 2 sec faster than the last time out at the track I tested on with new tires and shorter gearing, so I would guess I would be right back where I was before, if I was on the 8041 Yellows.
For the money and for entry level, the 8041 are fine, Tein Monoflex are better and I feel the R1 will be the best single adjustable shock out.... then once you get into two way dampers and beyond they are in a whole 'nother league!
As far as springs, I use the 2.5-inch by 7-inch Eibach ERS springs with helper springs. You can buy everything from Eibach if you purchase the shocks and order any spring rates that you prefer.
Well the Eibach Multi-Pro R2 are similar to both of those in overall feel. I think they are all great shocks, but all have a different target price. For the value and performance results I wanted, I found what I was looking for in the R2. It is hard to directly compare because each of the shocks have different off the shelf valving, design, and different adjustment ranges. One may be better in a certain area than the other. However, generally speaking they are all fairly similar. The most important thing on any double, or triple etc. is to make sure they are valved to properly control the spring rates you choose, and to know what you are doing with the adjustments and be able to have a sense/feel for the changes.
Do you buy the off the shelf eibach? or did you have them valve to your specs?
Thread back from the dead...
Does anybody know who makes the shock for the Eibach R2's? I doubt they are manufacturing them themselves. Is it Bilstein? Can Eibach do custom valving on the shocks?
We can do custom valving if really needed, we have had really good feedback with the "off the shelf" valving. .
Everything is done here in house in Corona Ca. Raw material storage, machining, Tig welding and assembly is done under one roof. The only thing we do not do is the polishing of the bodies or anodizing.
We have seen guys run up to 1000lb/in rates without revalving. That is higher than we tested with here, but they appear to be working for those guys. I have an EG with ITR lower arms and am currently running 700/600lb/in rates and have had good success with those. Not sure if it would be considered a "sweet spot" but we have seen a good amount of people running in the 600-800lb/in range with good success. A lot of that really has to do with your personal preference on how the car feels.
