Differance in Nuespeed race for eg/ek
I have a line on some lightly used nuespeed races that would surely be better than the s-techs currently on my car. The problem is the springs have the part number for a 96-2000 and I am putting them on my 93 sedan. Does anyone know if these will sit higher or lower than the part number for my car. I just don't want the car to be too low.
Re: Differance in Nuespeed race for eg/ek
well i used eg springs on my ek and had to cut like a coil and a half off the front to get it to sit evenly...keep in mind i cut the upper spacer spring id have to say install them and cut accordingly using a cut off wheel.
Im not really worried about the drop being even but based on what you're saying the ek spring will probably sit lower than the eg spring.
We put a set of s-techs from a EK onto a EG hatch a couple weeks ago. I can get a side shot / measurement for you if your interested then you might be able to compare it to how your car sits now. I do know that the NS race springs are really low. My friend has a set of them on his 00 coupe and they are the part number for his car.
Ok, I will try to have those for you tomorrow. The guy at our local race shop said that the rear springs are the same on the ek and dc, it is the fronts that are different.
aj_EGcivic
03-18-2008 05:09 PM
