Battery Relocation and SCCA Regs?
I am pondering on picking up a battery relocation kit from summit. My friend has one in his jetta which i helped install and he said he noticed quite a difference. I was wondering if there were any rules against this type of kit in any level of auto-X. If so, what level? This will be my first summer auto-Xing so I will def be starting out in amateurs. Any info would be much appreciated, tia
Re: Battery Relocation and SCCA Regs? (CivicSiRacer)
Also legal for STS/STX/SM
Re: Battery Relocation and SCCA Regs? (ajn)
That would bump you into SP.
What kind of modifications do you have done to your vehicle?
aj
aj
Re: Battery Relocation and SCCA Regs? (Knestis)
...he noticed quite a difference.
See also: Effect, Placebo
Kirk
Kirk
n. pl. pla·ce·bos or pla·ce·boes
1.)A substance containing no medication and prescribed or given to reinforce a patient's expectation to get well.
2.)An inactive substance or preparation used as a control in an experiment or test to determine the effectiveness of a medicinal drug.
iF YOU WERE TRYING TO HELP ME THANK YOU. IF YOU WERE TRYING TO CONFUSE ME, FAWK YOU BTW YOU DEF DID CONFUSE ME.
Actually you are in SM (Street Modified).
SP stands for (Street Prepared).
aj
aj
Re: Battery Relocation and SCCA Regs? (98Hatch00)
Even if you didn't install the battery re-location kit, you would still be in Street Modified because of the carbon fiber hood, camber kit, etc..
You're going to be in a class full of turbocharged Talons, Eclipses, Supras, etc..
Check your local autocrossing website and look at the results from a local autocross. Check out the cars that are in Street Modified. That will give you an idea of what you will be running up against.
aj
aj
What Kirk was trying to say is that relocating the battery to the rear of the car is not going to make that big of a difference with your experience.
Don't bring the attitude in here. There is a wealth of information in this board. Don't abuse it.
aj
aj
Re: Battery Relocation and SCCA Regs? (.RJ)
AJ is correct, the LCAs and CF hood will bump you to Street Mod. Don't sweat it, go have fun - there are always noobs to run against in SM since it's a very popular class.
wrx-killer-Sti-eater
Audio / Security / Video
60
02-19-2013 07:42 PM
